mypasswordis Posted December 20, 2009 Report Posted December 20, 2009 Uh yeah, so I'm failing pretty hard at figuring out why the right channel doesn't make sound. I checked the DCR from each tab of the dynamic driver (which is hooked up to the electret, yes I did mod them so it's not run through the electret into the dynamic driver anymore) and it measures correctly, around 330 ohms. Measured from driver tab to tip/ring and it measures the same. The hell am I doing wrong here? I resoldered the tabs just to make sure, still to no avail, and it's always the right channel, and not the left.
cetoole Posted December 20, 2009 Report Posted December 20, 2009 Could be that the voice coil is still intact, but has come unglued from the cone, or that the voice coil is simply displaced, so not in the magnet.
nikongod Posted December 20, 2009 Report Posted December 20, 2009 What cable are you using? If its the stock cable the diameter of the plug may interfere with a flange around the jack on some amps. As anohter guess at the same problem for a different reason, is the TRS jack lined up properly with the panel? When the plug isnt all the way in, the left channel plays the right signal, and right does nothing.
mypasswordis Posted December 20, 2009 Author Report Posted December 20, 2009 I.. don't even know how I'd go about moving the voice coil around without destroying everything so I hope that's not it. Yeah I'm still using the stock cable. I've tried it on a couple of receivers and the headphone out of my 0404 USB, all with nothing out of the right channel, even when I try to jam the plug in there all the way or roll it around. I used to get intermittent sound, at least.
mypasswordis Posted December 20, 2009 Author Report Posted December 20, 2009 I wired it up with some crap headphone cable that measured 3.1 ohms on one side and 3.3 on the other but at least now it's bi-entry which means it may sound better.
mypasswordis Posted December 20, 2009 Author Report Posted December 20, 2009 Couple of notes: 1) I'm pretty sure I have the bass light variety. 2) These are a lot more efficient than my orthos. 3) They don't suck as bad as I thought a semi-closed dynamic would. In fact they may actually sound good after a bit more modding. Might be the electrets? 3) Everything sounds better on vinyl. 4) I need to fix my Concept CE-H now but don't have any more crap headphone cables to solder on. Time to buy cheap vintage headphones for the cables. 5) I need to finish the JFET amp and make sure not to blow anything else up. 6) But it's time to make a recording first.
laxx Posted December 20, 2009 Report Posted December 20, 2009 So are you getting sound from both channels now?
mypasswordis Posted December 20, 2009 Author Report Posted December 20, 2009 Er, I guess I forgot to mention that part. Yes, yes I am. Thanks for the help, guys. I'm glad it wasn't the voice coil being displaced or I'd be screwed.
