How do I tell a fake OPA627 637 from real
I have several OPA627 and OPA637 in 8 pin dip.  Some I ordered from digikey, some from ebay that could've been digikey samples and some from ebay that aren't.
The problem is I acquired some when there were some fakes going around.  I didn't separate one order from another and put them all together.  I'm sure some are real and some are fake but is there a definitive way to tell?
Measure the resistance between the V+ pin (7) and each of the "trim" pins (5 and 1).
The real ones should all be pretty close, the fakes will not be.
There's a thread on HF about it.
I remember that thread and I think I went through it only to have more questions.
I'll try that tonight.  I'm sure one or two are fake because the logos aren't straight.  I'll see what happens
I've had samples from Ti and Analog Devices where the logo weren't straight. As mentioned resistance measurement and possibly even listening can point out the fake from the real pack.
I have batch 1
           1 637BP that's 220 Ohms off
           1 637AP that's 400 Ohms off
           1 627AP that's 170 Ohms off
I have batch 2
           1 637BP that's 0 Ohms off (dead even)
           1 627BP that's 80 Ohms off
           1 637BP that's 10 Ohms off
What do you think?
Edited by sbelyo
Could be factory rejects. Maybe try giving them a listen and see if you can point out any discernible differences apart with your ears.
There's this as well...
Try red on pin 1 and black on pin 5, then black on pin 1 and red on pin 5, both measure should read 45-55K
Did you try a similar test (measure with red and black probes one way, then switch them) for the 5&1:7 test?
Meters sometimes switch diodes/transistors on and mess everything up.
Looking at the datasheet for the 627 I have no idea how this would happen in real life, but it is easier to check both ways than think about :)
I did not keep track of red or black on the 5&1:7 test.  I will retest when I get home as well as test between 5 and 1
Measuring resistance with a handheld meter seems like an odd idea. What about comparing slew rate?
I have never done that bfore.  Does require a scope and a signal generator?
Large and small signal response would be good as well. The real question is how good are the fakes? If they are good enough to best your measurement equipment (the real ones likely will) then its not a feasible test. The question is how large is the gap...
 batch 1 difference between 5&1:7 both ways
Measurement of resistance between 5&1 all fall between 45 - 58K both ways
batch 2 difference between 5&1:7 both ways
I'm ready to call them all real.  I have no other means to test other than to listen to them in a circuit.  What do you think?
If there is a small etched part code number you can maybe email Ti to confirm its authenticity. Other then that you can test or listen.
yes, they all have a code,  I'll email TI on monday to see what they say
