October 1, 20178 yr On 9/28/2017 at 7:37 PM, archosman said: Bumping up the thread... has anyone run speakers off of the Impedancer? I was given a pair of Emotiva T1s and don't really have an amp to run them. The specs on the speakers are: Efficiency: 88 dB (2.83V/1m).Power handling: 150W continuous / 300W peak.Nominal impedance: 4 ohms.Frequency response: 37 Hz – 28 kHz (+3/-3 dB).Crossover (midrange / tweeter): 2700 Hz, 12 dB / octaveCrossover (woofer / midrange): 275 Hz, 12 dB / octaveDual speaker terminals for bi-amping or bi-wiring. Would this work or would it tax the RKV? Let us (me) know how the T1's are, I was seriously considering them at one point. On 9/28/2017 at 7:37 PM, archosman said: Bumping up the thread... has anyone run speakers off of the Impedancer? I was given a pair of Emotiva T1s and don't really have an amp to run them. The specs on the speakers are: Efficiency: 88 dB (2.83V/1m).Power handling: 150W continuous / 300W peak.Nominal impedance: 4 ohms.Frequency response: 37 Hz – 28 kHz (+3/-3 dB).Crossover (midrange / tweeter): 2700 Hz, 12 dB / octaveCrossover (woofer / midrange): 275 Hz, 12 dB / octaveDual speaker terminals for bi-amping or bi-wiring. Would this work or would it tax the RKV? On 9/28/2017 at 7:37 PM, archosman said: Bumping up the thread... has anyone run speakers off of the Impedancer? I was given a pair of Emotiva T1s and don't really have an amp to run them. The specs on the speakers are: Efficiency: 88 dB (2.83V/1m).Power handling: 150W continuous / 300W peak.Nominal impedance: 4 ohms.Frequency response: 37 Hz – 28 kHz (+3/-3 dB).Crossover (midrange / tweeter): 2700 Hz, 12 dB / octaveCrossover (woofer / midrange): 275 Hz, 12 dB / octaveDual speaker terminals for bi-amping or bi-wiring. Would this work or would it tax the RKV? On 9/28/2017 at 7:37 PM, archosman said: Bumping up the thread... has anyone run speakers off of the Impedancer? I was given a pair of Emotiva T1s and don't really have an amp to run them. The specs on the speakers are: Efficiency: 88 dB (2.83V/1m).Power handling: 150W continuous / 300W peak.Nominal impedance: 4 ohms.Frequency response: 37 Hz – 28 kHz (+3/-3 dB).Crossover (midrange / tweeter): 2700 Hz, 12 dB / octaveCrossover (woofer / midrange): 275 Hz, 12 dB / octaveDual speaker terminals for bi-amping or bi-wiring. Would this work or would it tax the RKV? Edited October 1, 20178 yr by recstar24
October 2, 20178 yr 19 hours ago, wink said: More bumps than forty miles of bad road.... (Old Duane Eddy fan) Sorry! For some reason I would click quote, submit, nothing would happen, would do it again and again, and it actually did submit as you can see.
