May 6, 200818 yr Hi guys Just finished my Bijou. It's only got about 20 minutes on it so far, but this thing sounds great. I'm currently listening to Fiday Night in SF with my K701 - very sweet. I'm not so great at describing the sound, but this amp certainly delivers - to me at least. Cheers Oh, I've temporarily mounted it on a piece of board so it looks pretty ghetto, so I won't post pics.
May 6, 200818 yr Fixed it for you Oh, I've temporarily mounted it on a piece of board so it looks pretty ghetto, so I will on't post pics.
May 6, 200818 yr Author Here it is: Dodgy photos, but you get the idea. Ignore the dodgy ICs. I had to place it away from my usual gear so I don't come too close to that 300V!!!! Now listening to Iron Maiden - this amp rocks..... hard. K701 rocking?
May 6, 200818 yr Author I'm not really sure how to adjust the negative feedback yet. I played with it for about a microsecond. I'd rather just listen to this beasty.
May 6, 200818 yr Author what's the dial above the headphone out? bull crap Should be the adjustable feedback. From the Bijou Site http://www.cavalliaudio.com/bijou/bijou.php The Bijou is equipped with a variable NFB circuit. This helps the amplifier handle the range of headphone impedance from 32R to 300R. However, very little feedback is needed for high Z headphones. Some listeners may prefer no feedback at all.
May 6, 200818 yr Awesome! You guys make some really cool stuff. I wish I had the brains/skills to make neat amps 'n stuff.
May 6, 200818 yr Author Awesome! You guys make some really cool stuff. I wish I had the brains/skills to make neat amps 'n stuff. smeggy Your ECR-500 write up is great. It looks like you've got some great wood working skills. I'm assuming that you turned those timber pieces? I've been very fortunate that there are a lot of great DIY amp projects and plenty of community support. I'm just a gumby who is learning to weild a soldering iron. I started small with CMOYs and such and have not worked my way up to the higher voltage stuff. It's a bit intimidating, but with a bit of patience and a lot of care, it's working out. It's a great cost effective way to have some pretty good amps at a decent price. The Bijou will end up costing me about $400 all up. Now just got to get a case to make it look less ghettoriffic.
May 7, 200818 yr Heh, I'd want to bypass all the cmoy stuff and delve right into a Blue Hawaii and likely kill myself
May 7, 200818 yr Author smeggy stuffing a board is pretty straightforward if you pay attention to a few things. Trouble shooting requires a bit of practice. In fact, that's probably the real benefit of working your way up. The case work is one of the most challenging parts of the build. Woodworking skills would be a real benefit in casing.
