Introducing the MA-009 - aka a quest to make the SR-009 suck a bit less...
Now it shouldn't come as a massive shock to anybody but I'm not much of a SR-009 fan.  From day 1 they always sounded messed up to me and the BK and S didn't really make it any better, even a bit worse with the 009S.  To this day I have only one 009BK (as it is a limited edition) in my collection and one regular 009 that showed up here randomly and was a stark improvement over all the other sets I've owned.  No idea why those sound different but better not mess with them.
Now the plan was always to do something with the 009's to improve them but there was always something better to do.  Well with surgery pending a couple of months ago, I finally had time to do something not too taxing.  First off I needed a donor set and here is where that came in:
I got these three years ago and they just sat there in a box.  Too many parts missing with no spares available, three out of the four dust covers were trashed and I took off the arc to rescue another 009... so a pile of parts with fucked up drivers.  The plan forward was clear though, the drivers needed new dust covers, new diaphragms, a way to mount the cable and finally some way to attach the earpads which wasn't 009 levels of stupid.  Now none of those parts could be reused or they simply weren't there so time to do some designing.  I still suck at 3D design but practice makes perfect... or it should in theory.  ;)
Now first off, dust covers and diaphragm holders.  These are easy to do as PCB's but materials, thickness, films used etc. are all large variables.  Here are my first drivers, actually using the third batch of diaphragms as I slightly tweaked the dimensions once I started test fitting:
Those familiar with the stock drivers might spot the bias connection is very different.  I had to spend a lot of time cleaning the stock drivers, as they had been open for who knows how long, but this first test was successful.  Fully balanced drivers and no noises from them at all so they are as clean as I can get them.  The dust covers are 2um mylar-C, just lightly stretched (hence the slight lines visible) and the main diaphragms are also fairly loosely stretched 2um mylar-C, then heat treated and given a coat of fabric softener.
The drivers are easy to align but one major part of this project is to find all the correct o-rings used to assemble these and in the right grade.  When I had waited a month for a large shipment just for the one size I needed to not show, I even bought some stupid expensive examples locally.  That got me here:
All new screws used to get the drivers into the housings.  You can see how beat up the aluminum housings are but hey, fine for a project like this.  Now there was the next difficult bit, the cable entry:
On the stock set it is a plastic guide which sits in those holes, the cable fits in that and the whole assemble is screwed down.  Now the stock cable I had was not perfect so instead of making my own version of that... I just used a standard Lambda cable.  A L500 was going to die for this set anyway (as I needed the arc) so why not use that cable.  Here is my solution for that:
This is 3D resin printed and is the second revision.  First was just to check for hole size, alignment and if it was fouling on anything but it was way too shallow.   This version still had to be sanded a tiny bit but it fits nicely.  I did make a 3rd and 4th version which is incoming to clean up the design a bit and give me some more internal room.  The earpads above are simply stuck on with some blutack so more on that...
For the earpad mounting, there two problems there really.  None of mounting hardware was included and anybody who had changed the 009 pads knows just how fucking stupid that mounting setup is.  I also wanted to use non Stax earpads (not paying 300$+ for pleather crap) so here is what I came up with:
Same idea really but I added a spacer between the plate and the driver housing so there is room to slide the lip of the earpads underneath it.  The two layers of the PCB sandwich are visible there (along with the production number as I forgot to have it removed) and it works nicely.  I could have made this from aluminum but it wouldn't have cost roughly 4$ then...
This is the fitment with some random test earpads and standard 1.6mm PCB's.  Works just fine and I can't find any issues with baffle seal... quite the contrary really.
So here we are, the MA-009  :D
This set of earpads has already been replaced and it takes a matter of seconds to swap them over.  What a novel feature...
Now what was the true goal for all of this, well besides having some fun doing something new... make a set of 009's I would actually want to sit down and listen to.  Now this project is far from over but here is something novel... a SR-009 that has some actual bass output.  They are still forward sounding but it has been diminished by a large extent.  I can use these for hours quite happily, even at my usually higher volume levels.
The decision to use 2um mylar was to try and tame that forward edge and it has been partially successful.  A stock set of 009's is terrible on most music I try them with, this one is mostly good with just some tracks which show how bad that stator design really is.  There is this slight forward sheen over everything and it simply has to be the stators as the rest of the headphones has so much in common with the 007 overall design.
Now the major issue is driver stability as the left diaphragm really likes to get stuck to the stators and I have to open up the driver to get is back on song.  I might have gone too far in sealing them up but I wanted some bass dammit!!  :)  I will make some more test diaphragms and see if I can make some which can handle the pressure of going on the head energized while giving the sound I want.  For now I'll just use this pile of parts to make some music...
So to end off... if anybody has a set of 009's with blown drivers that are collecting dust... hit me up and I might want to buy them.  ;D
  • Like 12
  • Thanks 2
