September 30, 200818 yr comment_165013 Does anyone know of a source for tape drive belts? I'm curious as to what's out there. Report
September 30, 200818 yr comment_165016 Galibier's support page has a few links for tape sources and splicing tools: Galibier Design - Support Page Report
September 30, 200818 yr comment_165020 yeah, go with the tape drive. I really like the way the silk is working for me (plus, the Nottingham won't work with tape), but I think in theory the tape is better. It would be interesting to see if you could do some sort of direct drive like that new VPI monstrosity... Report
October 1, 200818 yr Author comment_165035 I had noticed that the Galibier tables used some different looking tape belts, but couldn't find anything about them on their site. I guess I haven't seen the new VPI yet. I like the silk, but wanted to try out some different tapes. Report
October 1, 200818 yr Author comment_165038 Ah, OK I am familiar with that. It seems to kind of go against the whole motor isolation idea though. Wouldn't the motor vibration be carried into the platter with that system? Report
October 1, 200818 yr comment_165040 Possibly, even according to Harry Westfield of VPI. Check out Hoffman forum's thread on this because it has other links that follow the issue. Report
October 1, 200818 yr comment_165044 That's pretty cool... I've noticed idlers are getting popular. Report
October 1, 200818 yr comment_165059 That's pretty cool... I've noticed idlers are getting popular. I dunno if I'd call that an idler..the motor shaft is coupled to the "pulley".. Report
October 1, 200818 yr comment_165122 I dunno if I'd call that an idler..the motor shaft is coupled to the "pulley".. Yeah I know. Still about as close Harry Weisfeld is going to get to sell an "upgrade" to VPI owners Though going purely off memory the SSM is the only modern VPI table that doesn't have a notch in the plinth for the motor. yeah, go with the tape drive. I really like the way the silk is working for me (plus, the Nottingham won't work with tape), but I think in theory the tape is better. Is this because the silk is more prone to stretching? I believe that was one of reasons Dacron sutures were preferable to silk in certain people. Edited October 1, 200818 yr by deepak Report
October 18, 200817 yr Author comment_168708 yeah, go with the tape drive. I really like the way the silk is working for me (plus, the Nottingham won't work with tape), but I think in theory the tape is better. It would be interesting to see if you could do some sort of direct drive like that new VPI monstrosity... You know I've been thinking about this for a while now. Would it be as simple as finding a large pulley to attach to the Maxon motor/pod and wrapping it with a large rubber O ring? What about a wooden pulley/drive wheel? Report
October 18, 200817 yr comment_168711 yes, but you'll have to do some math to see if it will work. Depends on the "gear" ratio in this case, or the pulley diameter to platter ratio. This will tell if the Maxon will be capable to drive. The other issue is eccentricity (?) of the pulley, thereby ensuring that the pulley won't introduce an undulating motion into the table. This would cause sonoriscity failure. Report
