Augsburger Posted November 5, 2009 Report Share Posted November 5, 2009 Ok, in true Head Case fashion I have decided I need a higher end audio card for my office system. Currently I am running windows XP foobar and iTunes out via usb to my PS Audio balanced dac. The PS Audio dac will sample out to 192 but as you know usb will only go to 96K and I can't seem to get ASIO4all to load onto my computer so the better solution would seem to be to spend some moolah and just take a great leap forward. I am currently acquiring more and more 192K music files so I would like to experience the full extent of what my office system can offer while I am still alive. It seems that Lynx sound cards are highly regarded and can output 192K. There is the Lynx AES16e-SRC, and the Lynx AES16e and the Lynx AES16. Which would you recommend to do the job or would you recommend any particular RME sound cards? Or something else? Thanks for any enlightenment. Quote Link to comment Share on other sites More sharing options...
cetoole Posted November 5, 2009 Report Share Posted November 5, 2009 I believe the musiland usb-spdif can do 24/192, and do it async at that. Quote Link to comment Share on other sites More sharing options...
Augsburger Posted November 5, 2009 Author Report Share Posted November 5, 2009 Thanks Colin. Quote Link to comment Share on other sites More sharing options...
Icarium Posted November 5, 2009 Report Share Posted November 5, 2009 I own and like my RME 9652 for the purposes of digital output. Why the 9652? I believe it's the cheapest card that will have latest driver support. Quote Link to comment Share on other sites More sharing options...
swt61 Posted November 5, 2009 Report Share Posted November 5, 2009 Colin is the Musiland Monitor 01 USD simply a USB to spdif converter, or is it actually a soundcard to be connected to the computer via USB, then spdif into the outboard DAC. I ask because once my Buffalo32 is built I'll have the same need. Quote Link to comment Share on other sites More sharing options...
Icarium Posted November 6, 2009 Report Share Posted November 6, 2009 It's just a usb to spdif converter. Quote Link to comment Share on other sites More sharing options...
cetoole Posted November 6, 2009 Report Share Posted November 6, 2009 Colin is the Musiland Monitor 01 USD simply a USB to spdif converter, or is it actually a soundcard to be connected to the computer via USB, then spdif into the outboard DAC. I ask because once my Buffalo32 is built I'll have the same need. What is the difference? Quote Link to comment Share on other sites More sharing options...
Augsburger Posted November 6, 2009 Author Report Share Posted November 6, 2009 Icarium, Thanks for the suggestion, it is greatly appreciated. My goal is to have the best most accurate feed from my computer to my balanced dac, to my limited knowledge that means finding some gear that outputs bit perfect from my computer to my dac. My understanding is that with usb to spdif converters the signal is converted but the signal is not converted to a bit perfect signal. So in order to to output a bit perfect signal from my computer to my dac I need 192k output capable sound card, eg Lynx or RME. Quote Link to comment Share on other sites More sharing options...
cetoole Posted November 6, 2009 Report Share Posted November 6, 2009 There are both USB and PCI converters which output bit perfect, and those which dont. Quote Link to comment Share on other sites More sharing options...
swt61 Posted November 6, 2009 Report Share Posted November 6, 2009 What is the difference? Uhm yeah, good point. I guess once you send the signal you want to the DAC that's pretty much it. Hey I just claim to have a big wiener, not a big brain. Quote Link to comment Share on other sites More sharing options...
Augsburger Posted November 6, 2009 Author Report Share Posted November 6, 2009 Well I guess i will give Musiland a try then. Thanks Quote Link to comment Share on other sites More sharing options...
Icarium Posted November 6, 2009 Report Share Posted November 6, 2009 The only thing that matters is jitter + drivers and how painful they are/supported they are. And frankly while jitter is audible to me the driver thing is more important to me personally. That being said I've found used prices on the RME 9652 to be my sweet spot. That musiland thing though might be a great deal I should pick one out to shootout esp since my filthy hagusb is flaky these days. Quote Link to comment Share on other sites More sharing options...
Augsburger Posted November 6, 2009 Author Report Share Posted November 6, 2009 What prices have you found for the RME 9652? All my searches come in at >$500. Quote Link to comment Share on other sites More sharing options...
