September 27, 201015 yr comment_391166 Hey, I'm having a slot milled that will accept a piece of aluminum bar that is nominally 0.5" wide. How wide should I have the slot milled in order to ensure that the bar can be easily removed? I'm not sure what the tolerances are on aluminum bar and not really sure what extra width to account for that doesn't require a hammer to (re)move the piece. Report
September 27, 201015 yr comment_391170 I would guess that 1/64" over would be plenty large enough. Not sure what that is in mm., but in SAE it'd be 33/64". If it doesn't matter if the slot is a bit oversized I'd go with 9/16" just to be safe. Report
September 27, 201015 yr Author comment_391174 yeah, I was thinking 1/64" as well, assuming exactly 1/2" bar. However, I have no idea what the tolerances on aluminum bar are. Report
September 27, 201015 yr comment_391184 mcmaster carr has dimensional tolerances for most of their bar stock. A quick check of the 1/2"X?? got +/-0.014" as a worst case on the 1/2" dimension which is just under 1/64" (0.015625"). Report
September 27, 201015 yr comment_391228 Is it just the end of the bar that's going into the slot or are you sliding half the bar through the slot? If it's the former than it doesn't really matter since aluminum's pretty soft and it shouldn't be hard at all to file or grind down the end of the bar if needed. Report
September 28, 201015 yr comment_391229 CNC milling tolerances are typically +/- 0.005 unless you ask for better than that Report
October 6, 201015 yr comment_393194 What you need to consider is this. If the bar is nominally .5" ( Report
