November 11, 201115 yr comment_479953 Just got the Peak up and running. It was a quick setup so I just have the Tung-Sol in it now but it sounds great... clarity is right. Cannot wait to get my HD800's back this weekend. Right now I have the amp on a footstool next to my setup. With my planned setup, I will only have about 1" clearance between the 6SN7 tube and the next shelf. I assume that will be ok, the tube doesn't get too hot and there is a lot of room around it? Of course, it is not optimal for tube rolling. Edit: Guess I should have posted in the other Apex thread. Edited November 11, 201115 yr by shellylh Report
November 11, 201115 yr comment_480071 Excellent impressions blessingx. I'm on the loaner list about 3 weeks out. Its going to be an interesting comparison, as I'm pretty enamored with the GS1. Still, I'm looking forward to this, as I have three options for an amp upgrade. The GS-X is the easiest solution, but with the loaner program, the Peak and Arete shouldn't be ignored. Report
November 16, 201115 yr Author comment_480854 Todd was nice enough to shoot out the switching power supply so I was able to do some quick testing. Due to work and classes I spent less time here than earlier. HD800 used for everything. Is there a difference between the power supplies on the Arete and Peak? Yep. Not so much punch (at least with the previously mentioned albums) as atmosphere/space shaping with the Volcano - a (at least perceived) resolution enhance. It was so in both cases, though slightly more apparent on the Arete as I expect the tube on the Peak was performing some of the same 'atmosphere' duties. In fact, a tube change on the Peak is how you should probably think of the scale of changes on both. Obvious? Yes. Essential? Not at all. Would you spend an additional $700 for a better tube? In this range I expect many will upgrade, but my fear is that goal will prevent others from considering the base. Both stocks still clear the transparency test against the P-1u for instance. As I no longer have a GS-1 to compare, I'm not going to declare a winner, but my suspicion is the Peak or Arete with stock PS would at the very least compete extremely well. I could easily live with either Arete or Peak and the stock PS. And stock or Volcano I'm still confused which amp I prefer. Report
November 16, 201115 yr comment_480861 It's like asking if photography is better in color or black and white. Transparency or fun coloring? I think I need both really. Report
December 1, 201114 yr comment_483640 Got an email from Todd, and apparently I'm the next in line. It would probably have been posted by now. Report
December 1, 201114 yr comment_483694 Got an email from Todd, and apparently I'm the next in line. It would probably have been posted by now. I'll be sending it to you well before my two weeks are up by next Monday. I concur with almost everything Ric said. Really great amp. My review is on HF. Only difference is that I feel the Volcano PS is needed when using harsh or grainy headphones. Also some noise on very sensitive headphones like the Audio Technica's. Edited December 1, 201114 yr by purrin Report
December 2, 201114 yr comment_483781 ^ All in good time. I noticed the similarities in your impressions, and wonder how both of your respective DACs compare sound signature-wise. Report
December 17, 201114 yr comment_486733 I know you touched on it briefly blessingx, but if you get time, would you be able to provide a more detailed comparison between the Arete and Beta22? Report
December 20, 201114 yr comment_487514 I'd also be interested in that comparison ^^^. The Arete looks a great amp for the price. Now that I'm Zana-less I'm looking for something with good sound that works with a wide range of phones and is relatively toddler-proof. k Report
