October 20, 201313 yr comment_605168 Agreed, Ric. While the Herus probably is great, he probably hasn't heard much. FWIW, I pre-ordered the Light Harmonic Geek with upgraded output for $250 (didn't make the Kickstarter project). It's got a 3D Awesomifier.....must be good (Probably some kind of cross-feed implementation). I just ordered the same one in silver Report
October 20, 201313 yr Author comment_605174 Anyone with more technical knowledge than I have any thoughts on the Herus v. Geek from published specs? Like the pedigree and 1/4" jack on the Herus, but more seem to be going the other way. Report
October 21, 201313 yr comment_605218 He probably hasn't heard many DSD DACs (and gets a few names wrong), but... "Best Sound (highest value) – The best budget sound at the show was... The guy's name is Steven Stone. Didn't he once pitch for the Cubs? Don't trust him. He's a loser!!! (Ok, so he won a Cy Young when he was with the Orioles... but still, he's got the Cubs taint which can never be erased. Case in point: Bill Buckner. Need I say more? Buy this DAC and one day you'll be boarding a flight and you'll drop it just as you're stepping onto the plane. It will fall right between your legs and down into the tarmac.) Edited October 21, 201313 yr by Wmcmanus Report
October 21, 201313 yr Author comment_605335 RMAF 2013: Diving into // The Abyss | Confessions of a Part-Time Audiophile http://feedly.com/k/19Xjtm8 Report
October 21, 201313 yr comment_605343 So it's basically, add enough zero's and it must be awesome? God I hate these clueless blog idiots. Report
November 3, 201313 yr Author comment_607567 As LREs were talked about a bit after CAS...http://feedly.com/k/17A0YKr Report
