sbelyo Posted March 5, 2022 Report Posted March 5, 2022 Anyone ever try something like this? https://audioxpress.com/files/attachment/2685 I wanted to see if I could find something passive that would take an unbalanced signal from a preamp and convert it o a balanced output. Is this worth trying? Or would I damage the balanced amp?
n_maher Posted March 5, 2022 Report Posted March 5, 2022 There are plenty of commercial products (and DIY for that matter) that take a line-level signal and use passive components to create a differential signal. My first thought would be that if you're going to do that, it'd be something I'd argue is worth spending some serious $ on.
sbelyo Posted March 6, 2022 Author Report Posted March 6, 2022 I agree, I've found a few schematics online similar to the one I posted above. I see that edcor makes a similar one for $28 https://edcorusa.com/products/copy-of-pc-series-balanced-or-unbalanced-line-matching-transformers?variant=41110251962555 I think I'll order a pair just to see how it works. The Jensen transformers are $95 each. I also found https://cinemag.biz/line_input/line_input.php Do you think I'm fine with 600 Ohm | 600 Ohm like the article? The input would come from the lineout of a chord mojo and feed a Dynalo mini
dsavitsk Posted March 6, 2022 Report Posted March 6, 2022 https://www.jensen-transformers.com/application-notes/
sbelyo Posted March 6, 2022 Author Report Posted March 6, 2022 that's some good reading. I didn't see that. Thanks
audiostar Posted April 9, 2022 Report Posted April 9, 2022 Look up the Neutrik NA2 MD-0B-TX and Neutrik NA2 M-D2B-TX for this and enjoy. They are the same except for the black/red color on the chinch.
audiostar Posted April 19, 2022 Report Posted April 19, 2022 They have mini transformers build in and are just excellent (and very handy).
