July 4, 200818 yr Of course it's not an exact clone due to several changes, but I was wondering what opinions of the project might be. Check it out here/. I'm considering taking that and doing some mods to it or taking the Buffalo and building a DAC around that, or maybe even the PCM1794 or PCM1704. I'm just throwing this out here to see what kind of opinion I get.
July 4, 200818 yr Well I have the board and 90% of the parts that should be here any day. Not sure how long it will take before it makes music though.
July 4, 200818 yr Author Cool...knowing my own weak hold on my wallet, I'll probably end up picking up parts for it as well.
July 8, 200818 yr Author Any guesses on which might be better: a Buffalo with good output stage or the D1V3 Pass "clone?"
July 8, 200818 yr Just received the board and all the parts except the transformers and resistors. Should be fun stuffing this one. Lots of parts in tight spaces. As what would be better I guess I will only know once it's done. I would think that the Sabre8 on paper is a better DAC than the PCM63s but what really matters is how it sounds. Let you know in a couple days/month
July 8, 200818 yr Author Yeah, I would assume the Sabre8 is the superior part on paper, easily. I did order the D1V3 kit a few days ago, so I'm hoping it'll ship out by the 14th. I often see the PCM63 (along with AD1862) lauded as the best DAC chip ever for subjective sound quality, but you never know. I was mainly asking as I'll have to sell one or the other as I don't have the need or the cash to keep both around.
July 18, 200818 yr Did you decide if you're going to use the ESS or one of the PCM DACs? Interested how this turns out either way
July 19, 200818 yr I am currently working on stuffing mine. Takes a bit of planning on stuffing the parts. Makes doing 16 B22 boards look easy.
August 16, 200817 yr It's all up and running ghetto style. I have a DIR9001 receiver, PMD100 digital filter, and the PCM63P-K DACs. Many thanks to Pars for hooking me up with -V reg to get it going. So far I think it sounds very very good. I plan on letting it burn in for about two minutes to two years then compare it to the Buffalo. I might also look into adding a external clock and upgrading the analog PS caps.
August 16, 200817 yr It's all up and running ghetto style. I have a DIR9001 receiver, PMD100 digital filter, and the PCM63P-K DACs. Many thanks to Pars for hooking me up with -V reg to get it going. So far I think it sounds very very good. I plan on letting it burn in for about two minutes to two years then compare it to the Buffalo. I might also look into adding a external clock and upgrading the analog PS caps. you need some nice big Rifa PHE caps that would color coordinate with your build
August 16, 200817 yr I kind of like the way the BGs just give the rest of the blue capacitors the finger. "Fuck you. I'm red. What are you going to do about it?"
