Cardas Golden Presence interconnects
Has anybody tried these? I haven't found a lot of impressions by searching the web so far.
get the golden reference look at how cool it is inside all the air vacuum tubes and teflons and things. just spend extra and get the best cable tech in the world.
YOU CAN EVEN REPLACE THE "ULTRA BANDWIDTH GRADO WIRE" WITH REALLY ULTRA BANDWIDTH CARDAS WIRE
Remember, all that wide ultra bandwidth means more electricity, and more electricity down the cable means that when the electrons get to the voice coil wire leads on the driver its like the small bore hole at the bottom of the dam and the electrons go faster up the little wires which makes the headphone faster.
Normal cables are like a hole nearer the top of the dam because they're narrow and the electrons dont go as fast.
All righty, then. I'll call my dealer on the corner.
There's absolutely no reason not to get them. As duggeh said, the electrons move faster.
In fact, go right ahead and get the Golden Reference series. They're even thicker, and even more electrons get through, and they go faster too.
AND THEY HAVE MORE AIR TUBES LESS CAPACITANCE AND STUFF SO YOU CAN SAVE THE CAPACITANCE FOR BETTER THINGS LIKE HIGH END YELLOW COLORED MUSICAL CAPACITORS LIKE AURICAPS AND MUSICAPS AND CARDAS GOLDEN RATIO CAPS (HAS TEFLONG IN THEM AND IS BETTER THAN VCAPS AND OTHER ALL TEFLONG CAP BECAUSE ITS RATIOED AND WONT SMEAR TIME SA MUCH AS ALL TEFLONG)
REFERENCE IS MUCH BETTER THAN PRESENSCE I MEAN PRESENCCE DOESNT MEAN ANYTHING THE PRESENCE OF UGLY PPL DOESNT MAKE YOU HAPPIER BUT THE REREFERENCE LEVEL PEOPLE LIKE SEXY PEOPLE MAKE YOUR LIFE BETTER
They should have called them God cables. Let's not beat around the bush - it will obviously make that Norse demi-lamp wire sound tinny, closed-off, and artificial.
Golden Ratio. Damn. That shit is magic.
