Help finding a thread
I believe this was a thread started in 2006 or 2007 (on Head-Case with the old forum software). And I'm pretty sure 909 started it- it was asking about potentiometer replacements for a Moth amp. There were a a lot of suggestions in that thread, which then went off topic with marijuana jokes.
Does anyone remember this thread? I've used every possible search string I could think of and I still can't find it.
Admins- any way of checking if it was deleted by accident?
edit: I suppose the real thing I wanted out of that thread was where I could buy an ALPS RK40 from. I think someone posted a link to a German seller that had them.
Edited by deepak
I think you're thinking about his guy -
eBay My World - familygate
:dance:
Thanks Haj. "alps rk40" didn't turn up anything on ebay.de, I guess I needed the full part number.
I'm glad I could help. I do remember thread you're talking about, too, though I couldn't find it either.
Incidentally, I think you should go with RK50 and tell us how it is.
:rofl: still a resident
One problem with those RK40's , they are all linear and not log. While you can certainly make them work a RK50 might be easier in the end... ;)
Damn, I don't think it will fit my needs then. I need something that will track well (and has suitable adjust ability) at low/medium volume.
RK50...? :) TKD are also supposed to be nice but why risk it. :rolleyes:
The cost of pot:amp ratio would be outrageous :P
There is that... :( I do think that the pot is the most often overlooked part of any "pre amp" which is why I admire companies like Spectral which used the RK40 and Accuphase, Denon, Sony and etc. which used the RK50.
Clearly, the solution is to get a more expensive amp to keep the ratio in balance.
