Quick update:
it’s 6 AM here in California and I just wrapped up some late-night tweaking. Someone PM’d me earlier asking how I solved the offset and balance issue, and I can finally say: done. Offset is now around 0.3V and balance is about 0.2V.
If anyone else is running into similar issues, here’s what worked for me:
1.CCS Set Resistor: I kept the CCS set resistor at 1.5k, which gives around 22–23mA static current. You can try lowering to 1k if you want around 25mA, but I found 1.5k sufficient. The more plate current you have, the higher the offset you will get.
2.Cathode Resistor: Changed from 3300Ω to 7k–7.5k. A larger cathode resistor gives you a deeper grid voltage. I could only find suitable 7k wirewound resistors on Mouser – they’re a bit bulky but still fit. Note: Larger values will increase the offset, so some trial and error is expected.
3. Grid Pot: I replaced the 10k pot with a 50k, which gave me a much wider range to trim both offset and balance.
Final bias: around 24–25mA static current, Vgk ≈ -75V.
Hopefully, this helps anyone else dialing in the Megatron XL  and happy tweaking!😊
  • Replies 1.2k
  • Views 420.2k
  • dingding123
    dingding123
  • kevin gilmore
    kevin gilmore
Glad you find a way to adjust the offset.
With EL34 as CCS, +400V and offset close to zero, I believe 1.5K gives ~23mA and 1.0K gives ~34mA.
Edited by JoaMat
Thanks for the correction.
I actually paralleled a 3.3k resistor with the existing 1.5k CCS set resistor, which gives an effective resistance of around 1031Ω. Based on the measured voltage drop, that gives me roughly 24–25mA of current.
I believe the difference might come from my cathode resistor and grid voltage setup — possibly the cathode current is already limited before reaching the CCS. That might be why the current didn’t rise as much as expected even with the lower set resistor.
After paralleling with a 3.3K resistor an increase of a few mA seems reasonable, but what happened to the offset?
Paralleling a 3.3k resistor with the original 1.5k gave an effective resistance close to 1k, which I expected to behave similarly to using a single 1k resistor. After doing that, the offset increased significantly from around +12V to about +60V. So in the end, I reverted back to the original 1.5k setting resistor.
Thanks @Shawn.
I have ”gathered” some info from three sets of 300B, one 2A3 and one 6A3. To me it seems that they behave quite similar and need about 7K – 7.5K cathode resistors.
Your 50K trimmer (Grid Pot) will probably make it easier with the “fine tuning”. I guess you have put trimmers on the tube side of the board for easier access.
I actually kept the trimmers on the back side of the board. The PCB is mounted upside down near the top of the chassis, and I didn’t drill dedicated holes in the top cover for adjusting the trimmers. So each time I need to fine-tune them, I just tilt the whole chassis on its side and yes a bit inconvenient, but still manageable. A better solution would definitely be to make access holes in the top panel.
New solid state CCS for Megatron.
Now with a third pin for ground. The pins are made from 2.5 mm brass rod, which is almost 0.10 mm thicker than tube pins. PCB is a CNC milled one side 1.5 mm copper clad. So, no copper on top side of PCB. Holes for the three pins are 1.0 mm deep and you have 0.5 mm epoxy laminates left.
Transistor pins are protected with heat shrink tube and the exposed metal tab is protected with a 3D printed cover. The screw holding transistor to heat sink is electrical connected to it and to the ground pin.
The white base with guide pin is made of three 3D printed parts.
Edited by JoaMat
Interesting design! I’d be a bit worried about the thermal and mechanical side of things. The thermal resistance of the heatsink this size is probably going to run above 5C/W without forced air flow. It is going to run too hot to touch at 350V to 400V/20mA (7 to 8W). With 3C/W theta JC on the 10M90S, there is still margin on the die temperature.
If I were to design a PCB to be plugged into a tube socket with soldered pins, I’d use slightly undersized pins and whatever copper I can get for adhesion to the board (double layered board with plated-thought holes in 2-mm or thicker PCB), especially if the counterpart is the unforgiving “modern” tube sockets with tulip type spring contacts.
Last but not least, when the whole thing gets very warm, I’d use materials with higher working temperature such as ASA or ABS.  PLA is probably not going to last very long.
About the pin choice. I think this one might be closer to the original tube pins:
MPN:6835-0-00-15-00-00-44-0
https://www.mouser.com/datasheet/2/273/MMMC_S_A0004813843_1-2556643.pdf
I haven’t ordered it yet to confirm, but maybe it helps you.
Also, I’d like to get your advice:
At 400 V / 22 mA, would you consider setting Vgk around –95 V a good operating point?
I’m also thinking about increasing the static current to around 27–30 mA. From what I see, the EL34 max plate dissipation is ~25 W. At 400 V / 30 mA, that’s only about 12 W, so it looks safe on paper. I’d love to hear your thoughts on this.
Thanks for your comments, @simmconn.
The heatsink gets warm and user is aware of it. I think he is running at 400V/22mA and so far, it seems to work. If it gets too hot than he can’t use this thing - that’s life.
For pin dimension. The first version used Neutrik XLR3 pins. They were perfect, diameter slightly undersized. But to short to be soldered direct to main PCB. When looking for brass rod the best I found was 2.5 mm so, I decided to try that. 2.5 mm works with my Teflon tube sockets. The user is informed of that pins are soldered only on one side and if pins come loose, we have to find a better solution or perhaps abandon this thing.
I use Addnorth HT-PLA Pro filament. Better heat performance than PLA but not as good as ABS. I’m confident the socket isn’t a problem. It might be a problem with the transistor tab cover. I haven’t thought about the cover until your post - thank you simmconn. Now the user is informed, and he promised to keep an eye on the cover.
Thanks for the pin tip.
This beyond my understanding. But as I see it, with 400V/22mA the Vgk will be what it will be with offset zero.
12 W with EL34 shouldn’t be much of a problem. My EL61 will also handle that, I hope.
Once properly warmed up for an hour or so, the transistor legs sit at around 110, transistor casing at 100 and hottest part of plastic tab at 90 (all in degrees Celsius and with at least +/- 5 degrees or error possible; the IR-gun I use is not the most sophisticated). Definitely too hot to touch, though still a bit cooler than the EL34s :).
So a bit of margin on both die temperature and what PLA Pro can withstand, though I guess the latter will age quite a bit faster than it would at ambient temperature if I would leave the amp turned on 24/7.
I normally don't post pictures because my case work is rather poor, but I found a long exposure mode on my phone which after some experimentation captures the tube glow without leaving the rest in darkness, so I thought I'd make an exception. Pardon the somewhat battered front panel.
Should also add that it sounds great.
Thanks for your reply. I plan to test different combinations of static current and cathode resistor values to better understand how they interact. If I get some results I’ll come back and share them. For now, I’m planning to try around 27–30 mA of static current. It’s a bit difficult to find high-precision resistors around 1.2 kΩ, so on the cathode side I’ll probably increase to about 8 kΩ and see how it behaves.
I use LTspice to understand and to get a hint how things work.
I got this table with help from LTspice. Supply voltage +/-400 V,
Rupper is upper tube cathode resistor,
Rlower is lower tube cathode resistor, values give offset zero for given Rupper , the resistance is the total of paralleling resistors.
On 3/24/2023 at 6:53 PM, kevin gilmore said:
the spice simulations indicate that minimum distortion is set at about 33ma, so this is likely to eat about 300 watts total power consumption.  distortion will end up about .01% at full voltage swing.
Looking forward your findings.
Thanks a lot for the hint. Since I haven’t ordered the test resistors yet, I’ll probably need some time before I can try it out on a new build. But for today I did some measurements on the current operating point, and hopefully these numbers help add to the pool of data.
For easy comparison, I’ll use your same format. Based on the WE datasheet, I think both of our Vgk values are on the shallow side, but as Kevin has mentioned, modern 300Bs vary a lot, so I’m not 100% sure if this is correct.
It might make sense to raise the current to 33–34 mA, in which case the required Vgk would move down (according to the WE300B datasheet, Vgk at 34 mA / 400 V is about –90 V). My expectation is that as the current goes up, the offset also increases and Vgk becomes more negative. To bring the offset back to 0 V, you’d adjust Vg, but when Vg changes, Vgk may swing more positive again. If possible, it would be great if you could validate this in LTspice.
One more observation: with ±400 V supply, under load I measured about 389 V. I’m not sure if this is simply normal drop or if my current-limit is engaging. Could you let me know if your ±400 V rails drop as well? If yours stay right at 400 V, then I probably need to tweak my current-limit detection resistors.
I see no drop under load at +/- 400V, so you might be just on the edge of your current limiting.
I did run my XL at 33mA for a while which worked (and sounded) fine, but then changed back to 23mA to test some other stuff and right now it's dismantled for fitting of 2A3 heater supplies, so can't help with data points.
Edited by MLA
Thanks for the report. May I ask if you are using a GRHV supply?
And is your transformer secondary around 330 VAC for the ±400 V rails?
I just want to rule out whether my drop is caused by insufficient transformer headroom rather than the current limit itself.
It's GRHV with either 325V or 330V secondaries (don't remember exactly), and I lowered the current limiting resistor to 3.6R I think.
After some rounds of trial and simulation, I thought I’d put together a rough guide for setting the 300B operating point, mainly to make life easier when dialing things in.
Given static operating currents:
34.3 mA → Rk = 2160 Ω, Vgk = –73.7 V, Grid pot = 10 kΩ, set around 10%.
23.8 mA → Rk = 3200 Ω, Vgk = –75.8 V, Grid pot = 10 kΩ, set around 10%.
Plate voltage check (with Va = 0 V target):
At 34.3 mA → Plate Voltage = Va – Vk = 0 – (–325.9) = 325.9 V.
At 23.8 mA → Plate Voltage = 323.8 V.
By matching these points against the 300B characteristic curves (see the red-line markers in the attached graph), the theoretical Vgk comes out roughly between –70 V and –75 V, which lines up with the measured –73.7 V and –75.8 V.
From the curves, the 34.3 mA point looks more linear. Pushing current further could be even better, but that depends on whether the EL34 can handle it safely and whether the PSU has enough overhead.
All of these measurements are under a ±400 V supply. The 300B datasheet gives a max plate voltage of 400 V (though some manufacturers claim 450 V). On the XL build, with 400 V rails, the plate voltage is about 335 V, and still within a safe zone. I haven’t confirmed the behavior at 450 V rails, but I’d expect plate voltage around ~380 V, which starts to get a bit risky.
If anyone’s interested, I can run tests at 450 V and report back the voltages at each node.
Please do. Silk screen says +/-450V, I think.
I got this table based on LTspice simulation for supply voltage +/-450V.
Alright, here are the quick results.
Case 1:
Rupper = 1500, Rlower = 3200, G-pot = 10 kΩ (set at ~10%).
Va ≈ –1.7 V, Vgk ≈ –85.6 V, Plate Voltage = 362.2 V.
Case 2:
Rupper = 1200, Rlower = 2600, G-pot = 10 kΩ (set at ~10%).
Va ≈ 3.3 V, Vgk ≈ –85.3 V, Plate Voltage = 367.4 V.
I didn’t measure at 38 mA, since I wasn’t sure whether the EL34 would be overloaded, and I also don’t have the right resistor configuration at hand (Vishay Dale parts are really not cheap).
That said, you can see that in both cases the plate voltage stays in the 400 V max cell, which in theory should not be dangerous, but who really knows.
Thank you, Shawn. Good to know how Megatron XL behaves.
  • 5 weeks later...
A new daughter board to my Megatron something. It sets the grid potential of the output tubes. A few resistors, one trimmer set offset and the other the balance plus a small 120V GRHV supply completes the whole thing.
So, I removed cathode resistor along with its decoupling capacitor. EL34 has Vgk 40 V and 2A3 has Vgk 92 V. The amplifier has solid state CCS (no top tubes).
Works? so far so good.
Thanks to @JoaMat for posting the 2A3/300B auto-switching filament supply.
Although the picture isn’t very clear, I’ve been trying to figure out how it actually works.
I roughly recreated the layout (still very preliminary, no routing yet. So please note it may/does contain errors.
From what I can tell, the circuit likely uses the voltage comparator on the left to sense the voltage drop across a 0.05 Ω current-sense resistor, distinguishing the different filament currents of 2A3 vs. 300B.
The two optocouplers at the upper right appear to be controlled by that comparator and might handle auto-bias adjustment.
This is still an early interpretation. I’ll keep updating as I make progress or manage to get a cleaner schematic.
That looks really interesting.
Can I ask a quick question: Are the two trimmers on top each setting the grid voltage vs. plate current, or are they controlling the grid potential of each EL34 individually?
Also, is the 120 V GRHV section meant to supply the bias/grid voltage reference for the output tubes?
