Schematics auto switching. Not sure it's accurate, but that's what I've done.
New Grid Voltage Control boards.
One trimmer for offset and the other for balance so, both sides are controlled simultaneously. Two jumpers. For 300B/2A3, EL34 and EML 20B-V4. Works al right, quite easy to use.
The -510V is achieved with help from GRHV 110V supply. Here is one with Hammond 2VA trafo on board - 2.75in x 2in.
Okey, I've tried servo controlled Megatron (with solid state CCS) before and that failed...
Looking at the CTR curve I would choose the operating range between 1 to 2mA of If. Since the nominal CTR is 20%, the phototransistor side would be designed around 200uA to 400uA. Adjust the resistors such that the desired normal bias voltage is centered around this range. The phototransistor could operate off the 110V supply if you don’t need the full 510V range for the bias adjustment (why would you?).
I checked your schematic and compared it with your previous hardware photos, then corrected a few small errors(From both sides of us).
Here’s the updated layout. It’s basically reverse-engineered from the pictures you posted earlier.
I also derived the schematic from it, but it’s quite messy at the moment. If anyone’s interested, I can post that version as well.
Edited by Shawn
Fixed the layout
1 hour ago, JoaMat said:
I believe R41, FB2, C16 and C17 are connected as red line shows.
Eagle eye!
Good catch. I’ve updated the image and added the missing R41–FB2–C16–C17 connections as you indicated. Thanks!
Made a control board for filament smps today.
 Some pictures from my kitchen.
Idle voltage – no tube
2A3
300B
and EML 20B-V4
  • Like 7
It’s a pretty ingenious design. It takes advantage of the fact that a cold filament draws more current than when it’s hot and thermally stable. The circuit outputs 2.5V by default at no load in case someone does a hot-plugging. An 2A3 draws more current than 2.5A when cold, and gradually drops down to 2.5A. The output is maintained at 2.5V. If it’s a 300B instead, the current would drop further, say, below 1.6A. The circuit would then switch to 5V, and the threshold also doubles to 3.2A. There could be some brief back and forth, but as the filament gets hotter, the current will drop further towards 1.2A while the circuit stays at 5V output.
It should be okay for a DIYer to build a clone for his/her own use, but integrating the same in a “DIY” unit that sells for an atrocious price at “the marketplace” would probably be a different matter.
Three kinds of switching mode filament supplies made in my kitchen.
Right: Traco brick, only 5V with some fine adjustment, designed by Kevin Gilmore and slightly modified by me.
Left: DC-DC Step Down Converter XL4015, adjustable voltage and current limiter, have used it for 2.5V to 6.3V.
Middle: TPS62913 Low Ripple Buck Converter (green board) My own design but done with help of TI datasheet (all info needed is there). Copper color board is an Elekit regulator with 2A3 and 300B auto detection. I’ve added a trimmer for fine adjustment of voltage.
All three seem to work all right with my electrostatic amplifiers.
I also have Pete Millett, Tentlabs and Coleman filament regulators. They are all bulky with heat sinks and produces a lot of heat.
Yes, I do agree.
Yes, at some point it (probably) will be a different matter.
  • Like 4
A lot of those filament regulators focus on reducing the differential mode noise. I think the DHT would be more sensitive to common mode noise, because the filament itself is the cathode in the signal path. Depending on the circuit topology, you may or may not be able to bypass the noise to ground. The common mode noise starts from the secondary windings on the power transformer, and gets more complicated with the switching regulators noise riding on top of it. It depends  more on the implementation than the pretty numbers in the datasheet.
The one-trimmer control board above adjusted voltage for both 2A3 and 300B at the same time. No way to adjust voltage for one without effecting the other.
I assumed that it should be possible to set voltages for one tube and have the other unaffected. But as my brain isn’t as fast as the two comparators in LM2903 I made a test board with seven trimmers.
After some trimming back and forth I found one trimmer that adjusted voltage for both tubes and an another that just affected 300B,
So, next is a two-trimmer control board, same size as the one-trimmer. If you don’t understand how a circuit works, the trial-and-error method might help you.
Adjust R31 or R32 for 2.5V, and then adjust R33 or R34 for 5V. They should be independent as long as you do it in that order. Take into account of the wire resistance when measuring voltage especially in the 2.5A case, when you get into mV of accuracy.
Did this today. A two-trimmer control board. Here along with three one-trimmers.
One trimmer affects both 2A3 and 300B filament voltages and the second just the 300B voltage.
A small 120 V supply for above grid voltage control. 6.3VAC Hammond 229A transformer and LT8365 DC/DC converter. Out 120V . Size 2.3in x 2.3in.
Only in fantasy world...
Filament supply for DHT.
9VAC in and 2.5/5.0VDC out. Size 2.07in x 0.7in.
All you need is to connect a transformer and a tube to heat.
Edited by JoaMat
  • Like 3
A frendly Head-Caser has kindly lent me four EL156,
So, I made myself some EL156 to EL34 adaptors.
Here a Megatron SS CCD something with the four EL156.
Same friendly fellow has built himself a couple of filament supply for DHT similar to the one in above post.
  • Like 7
  • Confused 1
After almost a month of business travel, I finally had some time to follow up on this thread. It’s great to see that the filament PSU design has been making further progress.
Today I did a quick and very simple thermal check on a Megatron after about 30 minutes of warm-up using a basic thermal camera:
Transformers: max ~28 °C
Power supply section: max ~55 °C (MOSFETs + rectifier bridges)
1.5 kΩ resistors under the EL34s: ~67 °C
Overall the thermal behavior looks very reasonable and well within expectations.
Double-checked the gerber file of the Megatron XL today. It shows 47uf caps to gnd nearby the 12AX7. Don`t know if it should be .47uf instead of the 47. The rerber file name is megatron12vxl3fp ver .27
Edited by Shawn
Definitely 47uf. I put .47uf there by mistake when I built it; took days to figure out what I'd done wrong :).
  • Thanks 1
I put 100uF/16V electrolytics in those positions in my Megatron with solid state CCS.
I think it made a big difference.
Edited by JoaMat
What specific differences do you notice after adding the 100 µF caps?
Since it sits across the 10k to ground from the cathode, it acts as a cathode bypass cap.
Many things are said with emphasis in tube amp forums about how such caps influence the sound and whether they should be there or not if one wants further reading.
However, if you choose to have one, the important bit is that a small value like 0.47uf will reduce the bass frequencies quite a bit. Typical values applied to avoid that are 47uf and 100uf.
  • Thanks 1
