Could someone please post the final SquareWave schematics (or at least a picture of the PCB). I see some discrepancies in schematics/BOM/silkscreen published at http://tee8tee4388.blogspot.ru/2013/07/squarewave.html, e.g.:
  1. Schematics uses two opamps, but BOM and silkscreen have only one.
  2. Schematics and silkscreen have 402 ohm resistor, but BOM lists a 49.9 ohm one.
  3. BOM contains a 1n914 diode, but schematics and silkscreen do not use it.
this is the final and correct schematic
http://gilmore.chem.northwestern.edu/squarewaveproduction.pdf
if you are careful and match the fets, you can get rid of the 1500uf caps.
the original board had the servo inverted, hence the extra opamp
to invert the output.
latest stereo board
http://gilmore.chem.northwestern.edu/sqwave9.jpg
pair of boards installed in icariums SS1
http://gilmore.chem.northwestern.edu/sqwave10.jpg
the corrected mono board is also available.
R16 really should be 100k because the servo is too slow with 1M
you really want 100k. with 100k resistor, the servo gets it under 1mv in 30 seconds.
otherwise its a few minutes.
r7 and r8 can be up to .2 watt.  if you short the output, about .5 watt
and its a dual opamp in a single package
you can get rid of both electrolytics, or the one electrolytic in the latest board
by maching the fets and moving the left side of R21 to the junction of R1 and R2
and then shorting the bottom of R17 to ground.
Then its fully dc coupled, but you have to go thru a bunch of fets to get
the matching right.
More SquareWave questions:
1. Can the DC offset be stabilized with the output shorted to ground, e.g. closed relay in parallel with the load?
2. What parameters should the JFETs be matched for, Idss, Vp, Vgs(Ids)?
3. I'm designing my own SMT PCB (smaller 2-channel board). Can 2N4393 be replaced BF862 or 2sk209?
Thanks.
Too bad. I was using a mechanical switch to short Bottlehead Crack output before powering it up to avoid the turn-on thump (as suggested by one of the designers on the BH forum). Guess I'll go with relay in series with the load and make SquareWave look into 300Ohm resistor for the first 30s.
So any otl tube amp with a capacitor coupled output is going to have one
very large turn on thump. except for Mikhail's disasters that left the output
cap charged forever (black gates stay charged for months)
That turn on thump can be 50 volts or more. Not a good idea.
And the original cap coupled square wave probably had a 10 volt or more
turn on thump to charge the 2 x blackgates on the output.
Would using a 0.1uf 250vac rated mkp be a good move to suppress any in burst charge on power up on the switch? I've have some tube amps and some high voltage ss amps that use this on the switch (my Stax SRM1 has it).
Edited by DefQon
The Stax amps have a surge suppressor which is a cap and a resistor in series inside one box.  It's more to protect the switch than anything else.
