March 19, 200719 yr comment_27823 Fuck, I tripped over my headphone cable of my ATH-A100Ti, and bent/broke the plug. I also broke my soundcard in my computer, but care a lot less about that, since I usually use an external one -- I don't think I'll get that fixed. So I'm thinking: rewire it! So what's the best 1/4" plug out there right now? Does Cardas make one? Or should I just get any old one? Should I also recable my headphones while I'm at it? Or should I sent it back to audiocubes or eifl for fixing? Can that even be done? Actually, just tested it out on a different connection, it appears it still works, must be the soundcard that got disconnected on one channel. Report
March 19, 200719 yr comment_27824 Dusty, If the plug got bent at all I'd replace it, better safe then sorry. Now whether that's DIY or factory is completely your call. My preferred DIY connectors are as follows: 1. Canare F14 - nice plug, easy to use 2. Neutrik NP3X-B (or similar) - nice, easy, gold contacts 3. Cardas GRQ S S - can be a serious pain in the ass if you don't have lucifer's soldering station Report
March 19, 200719 yr Author comment_27828 Yeah, I saw the GRQ S S -- thanks for the warning about soldering. And yes, it definitely needs fixing -- it works right now, but I'll be using it minimally until I can get 'em fixed. Haven't decided on recabling them, though, going to look at them tonight based on inside info in terms of getting into them.Just throw those cans out.Fuck you, they're good. Probably my favourite unamplified headphone. Report
March 19, 200719 yr comment_27837 Dusty, Shoot me a PM if you end up needing a plug. I think I have both the Neutrik and the Canare on hand and it would save you the hassle of trying to meet some minimum order $. Also, one more knock on the GRQ plug is that it doesn't have any sort of strain relief mechanism built in, there are things that you can do but the other two are also easier to work with in this regard. Report
March 19, 200719 yr comment_27839 Fuck you, they're good. Probably my favourite unamplified headphone. Biggie has a well known love for Sony and Audio Technica headphones. Report
March 19, 200719 yr comment_27843 I may have a Canare sitting around somewhere as well..... those are the ones I've used in the past. I think the Cardas plug is slightly smaller and does sometimes have trouble making contact in looser 1/4 jacks. I seem to recall reading that somewhere. Report
March 19, 200719 yr comment_27844 Probably my favourite unamplified headphone.You must listen very quietly if you don't require any amplification... But seriously... if you aren't using an external amplifier woudln't a 1/8" jack make more sense? Report
March 19, 200719 yr comment_27845 You must listen very quietly if you don't require any amplification... You know, the boostero gives plenty o' volume. Biggie. Report
March 19, 200719 yr comment_27851 You must listen very quietly if you don't require any amplification... ROFL! Actually, this is true. I sometimes can't even tell if an amp is on at the levels Dusty uses. I may have a spare Neutrik plug around. Report
March 19, 200719 yr Author comment_27852 You must listen very quietly if you don't require any amplification... Actually, this joke of pedantry is kind of lost on me, since I actually do listen very quietly. But -- yeah, you know what I mean, no external amplifier.ROFL! Actually, this is true. I sometimes can't even tell if an amp is on at the levels Dusty uses. See? Thanks for all the offers everyone. I'm going to see what I can find out about getting it repaired from an Audio Technica serviceperson first, I'm also going to crack it open and see how difficult it might be to recable, but right now I'm waiting to hear back from audiocubes. Report
March 19, 200719 yr Author comment_27855 But seriously... if you aren't using an external amplifier woudln't a 1/8" jack make more sense? Actually, now that you phrase it like that, yes. So I think just plain reparation would be preference #1. Report
March 19, 200719 yr comment_27857 Well if it's an 1/8" jack you need I've probably got a little Neutrik that you can have for that as well. And I'm with you, I often listen at levels that probably don't need amplification at all. DIY Parts Warehouse standing by. Report
March 20, 200719 yr comment_27895 3. Cardas GRQ S S - can be a serious pain in the ass if you don't have lucifer's soldering station I've always used the fires of Mt. Doom for Vampire and Cardas connectors. Report
