I'll have the working unit at the MD/DC/VA meet tomorrow. Amp sounds great!
http://www.head-fi.org/t/754656/dc-area-head-fi-meet-george-mason-regional-library-sunday-april-12-2015-noon-5-pm
George Mason Regional Library
George Mason Meeting Room (on your left right after the entrance).
Date: SUNDAY. APRIL 12, 2015
Time: 12:00 Noon to 5:00 PM
Location: 7001 Little River Turnpike, Annandale, VA 22003
  • Replies 1.2k
  • Views 424.3k
  • johnwmclean
    johnwmclean
That meet is in my neighborhood, I might have to drop by.
by the way fully balanced version coming.
lots of parts!
100% differential
100% complementary
http://gilmore.chem.northwestern.edu/cfa3production.pdf
not sure why it took me years to come up with this
NO FEEDBACK of any kind
thd <.005%  and absolutely flat over the 10hz to 200khz
frequency response +0, -3db   .017hz to 4.43 MHz
Omfg, I'm going to need a bigger case. :)
Can you do the phase splitter as a separate board so I can add to what I've got?
Edited by GrindingThud
well the phase splitter is just the ubal to bal board.  and then there are pieces missing.
plus you would have to build 2 more boards anyway.
http://gilmore.chem.northwestern.edu/cfa3.jpg
for your thing, you could just adjust the gain to 1 and then use the ubal to bal board.
the stax mafia moves at light speed ::)
someone really needs to check this one over hard.
the miracle of cut and paste is not necessarily foolproof.
this is probably as close as I can get to the ayre stuff without actually having the schematics.
I could go all krell on this and stuff it full of power supply caps...
so what you're telling me is I need to donate a kxr to the Gilmore group
preamp plus power amp please.
I will send it back.
actually more interested in the amp, because I know I'm extremely close on the preamp part.
this really should be the end all dynamic amp, with 80 volts peak to peak output and up to
2.5 amps (more with a bigger heatsink) it should drive both hd800 and he6.
you could actually put the volume control in the middle for even more reduced noise, although
the noise is about 95db down.
Are you going to add a place for a pot between the splitter and amp sections? Might be useful, and you can always bypass it
I'm sure I will add that.
found a bunch of errors which hopefully I fixed.
and I took out the surface mount transistors because they are only 200mw  and there are a few places where its 270mw
picture updated
Ah, looks a little different than what I thought. I'll get the single ended version cased up before I move to the balanced one, which I think I will. Whats a few more boards. :)
Got a lot of puzzled faces at the meet today.... people somehow expect less when all the guts are hanging out. Once jacked in, it was all smiles and amazement. Most people preferred it to the Krell clone.
could it plossible just simply using 4 boards instead cfa3 design to complete balanced build? seems possible
thinking 4 board would be more flexible for me
sure you can do that, but you need a phase splitter, or have to run balanced input only
if you want balanced output.
doesn't the original design have feedback?
short detour to the post office today:
dual k170s and j74s from someone on diyaudio. should have a good home in the phase splitter
For CFA2 is it possible to up the gain to 7? I've not figured out how to do it with this circuit.
started to look at the layout for the phase splitter + cfa output
does your legend apply to the output only, or both sections? your schematic has 2s* parts in the phase splitter, and I seem to remember there being a version of the ubalbal board that accepts mps* parts.
Hmm you switched to SMD? Pity. Any chance to design them simultaneously please - SMD and all TH?
I've got plenty of MPSW.
