9 pin PC board teflon sockets?
Does anybody have a source? All I see so far is chassis mount.
if its for the kgst boards you want the machined ones also from parts connexion
you just don't use the chassis strap
parts connexion is good but they just double the price and charge shipping on the stuff they import from China that is otherwise found on ebay.
Teflon composite - interesting.
Any experience with gold versus silver plating? I used silver once for something I built years ago, which later resulted in green corrosion at the solder joint. I suspected it was because I didn't use silver bearing solder, I think I found that if you use silver plated components you have to use solder with trace silver (1% or something), which I don't have anymore. Any rate I like gold as it doesn't tarnish like silver. Thoughts?
PS. Not finding any on eBay at the moment.
Just use your own words - 9 pin Teflon.
teflon cmc 9 pin
Yes I saw those but I believe they are chassis mount. Spot checking they all mention chassis mount only
http://www.ebay.com/itm/NEXUS-MUSIC-Premium-9-PIN-9P-Gold-Plated-Teflon-Tube-Socket-12AU7-ECC83-2PCS-/181469359862?pt=LH_DefaultDomain_0&hash=item2a406aaef6
So are you saying these also will work in the KGST PC mount?
As Kevin said,
As Kevin said,
I did wonder what he meant by that, Parts Connection has the PC mount I'm used to (older style with leaf flanges) which is what I thought he was talking about.
Well thanks for all the help, learned something new and saved myself some money.
Bit late but could be red plague http://en.wikipedia.org/wiki/Red_plague_%28corrosion%29an electrolytic corrosion process on silver plated copper
Yes, it's fit.
post-3943-0-39005600-1424232273_thumb.jp
May cut pin shorter let sockets lower.
