Amplifier porn
9 hours ago, Craig Sawyers said:
Simple opposing magnets are not stable. The only thing that is stopping this instability is the jewelled bearings - but because of the magnetic instability there is more force on the jewelled bearings to apply a centering force that might be naïvely be expected.
I guess that is why the Castagna model A was pretty much the only tone arm to use the magnetic principle. Although at around the same era there was a design and prototype for a parallel tracking arm the used opposing magnets in a saddle arrangement; but that never made it to production.
Now it is now possible to levitate stably. The idea being the the repelling magnets are stabilised actively using a set of coils. Around 8cm diameter (so not small) and because of the active control a potential source of electrical interference near to the cartridge.
Then there is Meissner effect levitation. That is not entirely daft with high temperature superconductors. Of course it needs the superconductor to be cold enough, so a source of liquid nitrogen is needed. I've done exactly that as a table top experiment when my kids were small, and I was working at Oxford Instruments, so had ready access to chunks HTc superconductor, and a small expanded polystyrene pot for the LN2.
  • Replies 579
  • Views 191k
  • Knuckledragger
    Knuckledragger
    "I inherited my late father-in-law's system and need some guidance." says a redditor.  The system: Some father-in-law.  I married the wrong woman.  "Knuc
  • Craig Sawyers
    Craig Sawyers
    Designed by a guy called Steve Sells. I hired Steve straight from University back in around 1990 when I was running Engineering at Wharfedale. We were planning to re-launch Leak, and I said to Steve "
  • Knuckledragger
    Knuckledragger
    1977 Nakamitchi System-One.
3 hours ago, nikongod said:
https://oswaldsmillaudio.com/schroder_model_2
For another magnetic (ish) tonearm
I often wonder if the simplicity and negligible bearing friction of string or unipivot tonearms compared to more complicated gimbals is worth more than their tendency to wobble about any direction they feel like doing.
That is using magnets in attraction to apply a force to unipivot suspension string, presumably to resist the tendency to wobble. Attraction between magnets is of course stable.
  • 4 weeks later...
