CCS mod for 006t (t1 Variant )
Note that KG's boards are designed to use the ceramic insulators - you can see the thickness of the insulator outlined on the board where there are on-board heat sinks. Considering the minimal cost and the fact that they have been used on many successful builds without issues, I don't see the point in playing around with mica or silicon insulators, other than contrariiess.
Edited by JimL
  • Sad 1
Link to post
4 hours ago, JoaMat said:
Thank you. I’m particular interested with the insulating shoulder 7721-3PPSG as I believe this part is essential for the combo.
Yes it´s very interest. I use too ceramic insulator +7721-10PPG + steel screws, like others members and I never had have problems with this combination.
Edit... And I'm very careful not to stain anything with thermal paste.
Edited by jose
Link to post
1 hour ago, JimL said:
Note that KG's boards are designed to...
......won’t stop us from doing all kind of crazy things.:mikey2:
I've a secret - don't tell...  I never use thermal paste
Link to post
I'm not a big fan of using thermal paste either, but I've seen some photos where the transistors are quite stained.
Link to post
I like SPA2000-0.015-00-54 if using PEEK screws
Link to post
I don’t agree , when someone tells me on the internet that the specs are wrong on a part ... then why shouldn’t you test those specs .
And if you have something against testing when hv is concerned well , that’s just silly.
as an engineer I spend a lot of time testing to failure because that’s how we keep opinions in check over facts .
Fact is mica is thinner and at the same thickness has very similar thermal barrier property’s . So a thinner insulator less thermal resistance .
Whats wrong with looking for efficiency or better design
From the testing I’ve done so far you shouldn’t have any issues with this combo .  It would seam you can use mica with synthetic fastenings or ceramic with steel . I don’t use grease in testing because .. it eventually dries out and it’s dialetric property’s change so the test wouldn’t give a result that would account for that .
im actually looking forward to trying different compounds to see how much if any extra insulative effect they give .
this is just a blog of my personal little project , if it’s upsetting people they should probably just unsubscribe .
Link to post
I don't think that you are upsetting to anyone.
Link to post
JimL saying the purpose is  contrariness actually a pretty offensive thing to say to an engineer .
Its just an adventure in building some electronics , I didn’t decide to build the circuit just to be a dick about it ,
i started doing it because I wanted better sound ,
i started testing because I made a mistake , a potentially harmful one and I’d like to not make that mistake again .
Im still quite grateful to the fellow because it was his article that set me on this path and Kevin’s support that got me through it .
ps I’ve started acquiring parts to build a carbon ... so this should be interesting :)
Link to post
13 minutes ago, JimL said:
Sorry, didn't mean to be insulting. Carry on.
All good , if it wasn’t for the article you wrote I would still be sitting here annoyed at an amp that was sub par at best . I appreciate that you put it out there and it’s work like that that keeps diy alive and out there .
Its appreciated I guess all I’m trying to do with the testing is show the reasons behind why you did spec the ceramic insulators in the first place .
But for me missing that detail and using silicon , something that would have failed at even 500v , I wouldn’t have damaged my amp and had to repair it.
The testing so far has shown that a steel bolt with ceramic is good enough in fact it’s as good as a synthetic bolt and mica if not better.
Link to post
