What are my options for a really sweet single ended headphone amp?
Click for larger image.
One small correction. Ground one end of the OPT secondary for use with SE headphones.
Power supply schematic in another day or 2 when I get around to it.
  • Replies 85
  • Views 15.8k
Gimme a day or two to clean up and post the schematics. My weekend's been rather busy.
Do you have the schematic for the power supply done yet? That amp looks sweet.
Done, but that doesn't help since my scanner went tits up...
Is the Dynahi still considered to be at the flagship level of amps?
Flagship? Maybe the Dynamight, but I don't think either was ever at the flagship level, but maybe my definition of flagship is kind of off. It's certainly a very good amp still. But with the beta22 which is at least about its equal if not slightly edges it out depending on taste and the dynafet on the horizon... well unless you have multiple flagships for the DIY cause.
Thanks for the schematics aerius. I'm going to wait to see what Eddie Current has coming out.
