philodox Posted March 21, 2006 Report Posted March 21, 2006 They aren't in the signal path on the headphone output... but we're pretty sure they are on the XLR output. If they aren't, I would be interested in knowing how we are getting amplification. There are only two transistors in that area of the board and they are used for the relay's from what we could see.
blessingx Posted March 21, 2006 Report Posted March 21, 2006 Just got my Lavry ten minutes ago. Quick question for those with one: does the LED volume panel move when you increase or decrease the volume? As if it's not anchored down? Also I find it difficult to adjust the volume by a single digital as it jumps by two. This is more common up so I have to go up then back down. PFKMan23, is this the problem you had? Was it completely fixed? BTW, I just compared it directly against the TubeDAC+. Wowee Zowee.
Dusty Chalk Posted March 21, 2006 Report Posted March 21, 2006 For you direct-out fans: the new dCS P8i has (a) balanced outs; ( volume control; © balance control; and (d) voltage control (this is somehow different from volume control, I think). I read the new Stereophile review. I am expecting one of you direct-out knuckleheads to be trying this, soon. C'mon, take one for the team, it's only US$14K.
philodox Posted March 21, 2006 Report Posted March 21, 2006 Just got my Lavry ten minutes ago. Quick question for those with one: does the LED volume panel move when you increase or decrease the volume? As if it's not anchored down? Also I find it difficult to adjust the volume by a single digital as it jumps by two. This is more common up so I have to go up then back down.I would open it up and make sure it is firmly seated in there... I dont think my LED's move, though I will double check when I get home. you just need to remove the philips screws on the bottom and rear plate and it just slides out.
Grand Enigma Posted March 21, 2006 Report Posted March 21, 2006 Mine move a slight bit when I move the volume up and down... nothing too drastic so I am not worried at all.
PFKMan23 Posted March 22, 2006 Report Posted March 22, 2006 You should try the lavry paired with a good amp
tiberian Posted March 22, 2006 Author Report Posted March 22, 2006 Damn these highs are clean. yea, the lavry has a very, very clean treble.
blessingx Posted April 9, 2006 Report Posted April 9, 2006 You should try the lavry paired with a good amp Which ones have you heard with it?
PFKMan23 Posted April 9, 2006 Report Posted April 9, 2006 Well I do have my MPX3 (currently being messed with at SP...), but I'm also thinking about getting a balanced solidstate amp of some kind...
Post Posted April 27, 2006 Report Posted April 27, 2006 blessing, you are comparing it to a scott nixon tube dac+? that's one of my fave DACs, it would be interesting to hear a full blown comparo to that and the lavry!
blessingx Posted May 13, 2006 Report Posted May 13, 2006 blessing, you are comparing it to a scott nixon tube dac+? that's one of my fave DACs, it would be interesting to hear a full blown comparo to that and the lavry! Jahn, I loved the TubeDAC+ for as long as I had it (and still think it's a strong value), but there's really no comparison. Since the Nixons can be regularly picked up used for half the price of Lavry, it's impossible to state which is the better price performer, but on sound quality the difference is strong enough and on every level (detail, clean highs, balance, tight bass, etc.) that a detailed review isn't really necessary. I sold the TubeDAC+ soon after (and to finance) receiving the Lavry so doing one know would be fuzzy memory anyway.
edisonwu Posted May 13, 2006 Report Posted May 13, 2006 here are some pictures i took few weeks ago, larger pics as request..
tiberian Posted May 13, 2006 Author Report Posted May 13, 2006 this is an oyaide digital cable ad, where did you get your lavry from?
edisonwu Posted May 13, 2006 Report Posted May 13, 2006 hey, tiberian, I got my first LB from sound pure and the second one from lavryengineering. The lavry's did not come with the poster of Oyaide digital cable, A Oyaide tunami GPC powercord did.
