December 16, 200718 yr comment_79078 Any suggestions on how to properly clean out a battery compartment that had a minor battery leak? There's not much residue, but was curious what my best options are. Report
December 16, 200718 yr comment_79197 Acetone, maybe? The only time I've had to clean a battery compartment, I took the compartment out of the item, so I just washed it out and let it dry for few days. Report
December 16, 200718 yr comment_79205 Acetone might be a bit much for this. I'm not sure what you can use that would neutralize the crap from the batteries... I would clean it out as best you can. Maybe wipe it out with some alcohol or something once you have it pretty clean. I would also take something like DeOxit or contact cleaner and clean the metal contact parts. Report
December 16, 200718 yr comment_79208 your tongue! Actually what little i have have i just brush it off with the metal green cleaning pad thingy used for dishes. Report
December 16, 200718 yr comment_79209 ixnay on acetone - it may dissolve your battery compartment if it's plastic. Sorry about that - I completely forgot that bit about acetone. Report
December 16, 200718 yr comment_79225 You can do a search on google. The most useful link I found was www.wikihow.com/Clean-Battery-Leaks/Spills. What you do many depends on whether it was an alkaline or acid battery that spilled and it's unclear which it was by your description. Report
December 23, 200718 yr comment_80912 I always use 91% isopropyl alcohol on the plastic and the metal parts with a thin Q-Tip. Report
