The Quest for >2000 Vppss
the power of that part is 170mw.  so the stn0214 should work. make sure the pinout is correct.
mouser has thousands of ksc5026 in stock.
the extra diode cannot hurt. not sure what it is supposed to do.
  • Replies 90
  • Views 22.8k
  • This might be too crazy for me but why not go further.  I happen to have a couple of 30kWh, 400V battery packs so a DC-DC converter and make it "portable"?
  • kevin gilmore
    kevin gilmore
    so here is the latest version of the kgsshv-carbon  with the c3m series parts including the current source. Good for up to +/-600v power supplies. board file updated.     kgs
  • Merry Christmas  I made the output board for D&G and tested it with +/-400V and 845 tubes. Seems to be working as there's 44v across the cathode resistor. I was planning on using +/-1250
On 12/27/2025 at 7:06 PM, MLA said:
Test build of Super-Carbon up and running to see what is what:
PSU angle brackets are recycled from a previous, very tight, build, where those cutouts made perfect sense :).
Two small issues worth mentioning on amp boards. First, TTC004b and PZTA42 have opposite pinouts (ECB vs BCE) so if using TTC004b, transistor front needs to face heat sink. Second, you need to add some current limiting on the CS LEDs if you intend to use them.
Running at +/-550V.
No listening yet; need to build a more permanent CS supply solution first and also tidy up in general.
As soon as you guys start using IMGUR, we cannot see content in the UK. This is because the UK on-line regulator OFCOM is suing IMGUR as a result of lack of assurance regarding harmful content to minors (AKA under 18!). IMGUR has responded by simply showing a blue screen with "Content not viewable in your region" in large letters.
This describes the decision https://www.bbc.co.uk/news/articles/c4gzxv5gy3qo
IMGUR images look like this from the UK
personally I set my vpn tunnel location to the USA and then I can see the images... at least until the uk makes vpn tunnels illegal...
Somewhat ironic - since I'm not in the UK, your post is showing me exactly the same amplifier picture I posted earlier :).
I see the problem though and I think it's been brough up before in this forum. I was hoping for Imgur to resolve this, but if it persists and/or spreads I might look for another image host.
Here you go. I forward the previous pic. Should be visible now.
Excellent - thanks!
I'm only sorry we have such dick head regulators in our small island, spoiling IMGUR access for the 65 million crammed in to our speck of dirt.
Roughly based on the schematic Kevin provided (Based on the version with the extra 1N4007 diode), I did an SMD layout of the circlotron PSU.
Yes, it looks familiar. The layout was adapted from the GRHV SMD board and modified for this application. The board size is 51 mm × 31 mm.
The KSC5026 was replaced with STN0214, using a large copper pad underneath for heat dissipation.
The 10 Ω / 5 W resistor can also be substituted with 4.7 Ω, which is generally easier to source.
Don`t know if the two stn0214s can be replaced by PBHV2160.
Picture from work in progress (if there ever was anything else). I can now start the Super-Carbon without using the Variac.
Initially, the PSU SicFets blew up during startup when doing a full power on, very similar to what SimmConn reported here:
Presumably my SicFets ventured outside their SoA during startup. I'm not using the Cree C2Ms here (though it's a similar spec'd SicFet) and I have the current sources set for 25mA which might be pushing things a bit, so this particular problem may very well be unique to my build.
However, since this forum has a lot of clever participants :), the solution was at hand in the same thread. As per @Kerry's advice, I wired in the depletion mode MosFet current limiter directly after the pre-reg caps instead of having it after the post-reg caps. Also, I added a Vds clamping Zener as per @simmconn's mod.
Not skilled enough to tell which mod did the trick or if both are necessary (and one can of course never exclude the possibility that it now works for some other reason that I have no idea about), but anyway it now starts up without anything blowing up and I can move on to the "oh, I'm supposed to listen to it?" bit. Special thanks to Kerry and SimmConn (in addition to Kevin designing these things in the first place); I would not have figured this out without you!
Apologies to all UK members; haven't gotten around to finding a new picture host yet.
Edited by MLA
I believe Q12 (IXTH6N100) here is also acting as a current limiter, and it’s a depletion-mode MOSFET.
I’ve been thinking about slightly changing its placement: moving it ahead of Q2 (C2M), after the filtering stage. Since the C2M devices are now discontinued, they’re likely to become increasingly difficult to source going forward.
I realise I was a bit unclear above. The Q12 IXTH6N100 is indeed a current limiter and as I read the schematic, it's there to protect the whole psu should the amp board develop a short of some type.
So what I did above was "steal" my Q12 by re-wiring it for start-up duties instead (placing it between pre-reg caps and Q8).
However, that also means that my boards no longer have the Q12-based psu protection in place. So in the future, I will probably put a second IXTH6N100 on the board (in the Q12 position) to restore that protection.
 Also, you don't specifically need the out of production C2M parts for the psu. The next generation of those SicFets, specifically the current production C3M0900170D that also replaces the old C2Ms on the amp boards, work just fine.
Sorry. I didn’t read your post carefully enough the first time. Glad you’ve got a working solution.
My current thinking is: instead of keeping Q12 at the very end of the PSU, I’m considering moving it right after the rectifier and bulk filtering, and ahead of the C2M device. For the SMD version, I’m also thinking about adding a STR1550 locally next to the C2M to provide a second layer of current limiting. That said, as mentioned before, similar to something like a 2N3094, but who knows if it works or not.
The main goal of the SMD redesign right now is to merge the two circlotron PSU boards into a single board and reduce the overall size by roughly half. If space allows, I’d also like to see whether the 15 V golden reference and the CPC1117 delay / soft-start can be integrated onto the same board.
I have some ideas sketched out, but I haven’t started any actual layout work yet.🤐
I’ve mostly finished the layout at this point.
The current board size is 107 mm × 166 mm, and it integrates the following onto a single PCB:
Bias GRLV interface
Circlotron PSU interfaces
Soft-start circuit
Four IXTH6N100 Stand outside. Should be fine w/o heatsinks.
Both Circlotron supplies merged into one board. For reference, the original Circlotron PSU boards were roughly 176 mm × 190 mm per board, so the overall footprint has been reduced to well under half the original total area while keeping full functionality. The shrink seems reasonably successful so far.
There is one point I’m still not fully confident about (see Fig. 4):
C15, left side +HVAC-N — which rectifier bridge should this node reference?
In the non-floating implementation, it would naturally reference the rectifier feeding B+. However, once the supply is fully floating, I’m not entirely sure which point should be considered the correct reference for this connection, and I’m unclear which node I should be tying it to.
Any clarification on the correct reference point here would be appreciated.
Edited by Shawn
so the idea is to keep the voltage going to the 10m90s that drives the zener string  between 600 and 900v.
depending on voltage input, just a standard voltage doubler will push the voltage well above 1kv. and no reason for this. so in the very original spoilers, a pot was added to spoil some of the voltage that would normally have been generated by a standard doubler.
Edited by kevin gilmore
Cross-checked the layout of kgsshvcarbon6.1c3cs. Red marked the differences. Nothing wrong with the schematic. Just a couple of caps added to it.
And the shrink version Circlotron(CRHV) board has been shipped out from the manufacturer. Will report the result later.
kgsshvcarbon6.1c3cs.pdf
Edited by Shawn
OK. Did a first power-up test for CRHV today.
With 360k set for 550 V, I’m measuring about 554 V in practice. I only let it run for ~10 minutes. A quick IR check shows the CRHV peak temperature at ~58 °C.
I suspect running it from dual 250 VAC inputs targeting ~600 V output may result in slightly better thermal behavior.
At the moment, only the high-voltage section is populated. The delay soft-start and ±15 V sections are not installed yet, but they should function as expected once added.
image.thumb.jpeg.9842185080ae0d393df418b5beca2c73.jpegimage.thumb.png.f0169bd4f159ed3144e319f56ae8fe80.pngimage.thumb.jpeg.c84e122568aa1b77804e5f068c9d247d.jpeg
  • 3 months later...
On 12/30/2025 at 5:24 AM, MLA said:
Almost, but you also need to connect to GND on the amp board, so:
First, connect GND on the amp board to PSU1+ and PSU2 -. This is now your relative ground point.
For the PSU1 board, since it has + connected to GND, it's negative terminal will sit at -550V relative to GND, so connect that to B-.
For the PSU2 board, since it has - connected to GND, its positive terminal will sit at +550V relative to GND, so connect that to B+.
Hi, @MLA
I'm planning to test this next month, and I have one more question:
The low-voltage ±15V supply GND on the Carbon PCB is connected to the high-voltage GND. Does the ±15V supply also need to float somehow in this configuration, or should I simply connect the GRLV GND to the Carbon GND as normal?
I'm trying to make sure I understand the grounding scheme correctly before I start wiring everything up.
Edited by Shawn
As I remember it normal is what I did, i.e. same GND point for LV and HV.
How to calculate the resistor needed for the current limiter?
I believe you can change the value of R4 to adjust the current limitation.
I_limit = Vgs / 10
A gate stopper may be added for better performance.
Last week I finished assembling the Super Carbon, and it's now up and running. The first listening impressions are very encouraging, but there is still some audible background noise that needs to be eliminated.
At the moment I suspect it's related to the power supply compensation, possibly an oscillation. On the schematic, around the STN0214, there is a 470pF/1kV capacitor. I initially installed a 5pF/1kV capacitor there, so it's possible the compensation at that node is simply insufficient.
I'm currently waiting for some mica capacitors to arrive so I can experiment with the compensation network.
While simulating the circuit in LTspice, I measured approximately 540V VCE across the STN0214. Based on that, I don't think the PBHV2160(VCEO = 600V) is an ideal substitute for the STN0214, especially if you're targeting output voltages significantly above 600V.
On another note, I also performed the initial testing of the D&G 211 filament supplies, and they appear to be working as expected.
A small update on the Super Carbon troubleshooting.
After replacing the 5pF capacitor with the 470pF value shown on the schematic, the oscillation was reduced significantly. However, there is still a very noticeable background noise.
At this point I'm starting to suspect the XLR input stage instead of the power supply.
When I short IN+, IN−, and GND together at the input, the background noise disappears completely. That makes me think the input stage may simply be too sensitive.
@kevin gilmore do you think it would make sense to reduce R48 and R49 from 500kΩ to something like 200kΩ or 100kΩ? Or perhaps add a small capacitor for some RF filtering at the input?
I'd appreciate any suggestions before I start experimenting further.
the resistors are just there to make sure its stable with nothing plugged into it.
change the input resistors to as low as possible compatible with what is going to drive it.
10k is probably what i would do.
