Shut Your Pihole!
As I have mentioned in Jacob's Jacobless Jacobing, I recently bought another micro PC for the purposes of installing Raspberry Pi OS (in this case Raspberry Pi Desktop.) The more I learn about smart devices, the more I want to return to monke build a proper standalone adblock/anti-tracking machine. Seriously. We live in a schizophrenic's nightmare. That 4K LG TV is like the offspring of the Five Eyes and Mark Zuckerberg. Your "Internet of Things" refrigerator is phoning home to China. A Russian has hacked into your washing machine.
My solution to this Orwellian hellscape is try out a Pihole. Raspberry Pis, as devices, have become so cartoonishly expensive that it's actually a better economic decision to buy a low end micro PC (see above.) This thread will primarily serve as "lol, Knuckles thinks he's a linux geek" but will hopefully include at least a little useful info.
The new micro PC, a Beelink SER, arrived today. I learned that the other low power micro PC I bought in 2022, a Minisforum UM350, is significantly more powerful than the Beelink. The former has a Ryzen 3 3550H (4 cores, 8 threads, better per-core performance, Vega 8 graphics) and the latter has a Ryzen 3200U (2 cores, 4 threads, Vega 3 graphics.) This is actually a good thing as the UM350 can pull up to 35W (I think mine is rated at 20W, but it's been ages since I looked that up.) The 3200U pulls 15W. Obviously, I will be running the Pihole 24/7 once it's fully set up. Also, I don't exactly need 3D graphic performance of any kind with it.
The biggest surprise thus far is that I bought a unit that was not supposed to come with an OS and surprise, SUCKER! It's got Window 11 pre-installed. That OS is like a goddamn venereal disease. mikey2
This evening I downloaded the Pi Desktop OS image. It's a svelte 3.4GB. I'm not sure I have the energy at this hour to format a bootable thumb drive and begin the OS installation process.
Update 1 (of many): I successfully made install media on a thumb drive and was able to install Debian PiOS on the Beelink. The install process was mostly painless. There were a few points where I had to select something non-obvious to continue. Linux is FLOSSy and it never fails to show off that fact.
That's about the extent of the good news. Debian ships with Chromium. For the last half hour, I have been trying to install Firefox and ...completely fucking failing. I can download the tar.gz file sure. I can extract it. I have tried a number of directories. The extractor defaults to /tmp. I cannot drag the firefox directory out of /tmp and place it elsewhere. I made $HOME/Applications. I extracted FFX there. I found what I think is the executable. It will not run. I have done like 17 searches using DDG and the Goog on how to install FFX on Linux. The answers are remarkably unhelpful. I'm breaking for lunch.
Also, at the risk of accusations of preaching to the choir: Every experience with I have with Windows and now Linux is an argument for The Mac Tax. W11 is horrible in the most dystopian, Orwellian way imaginable. Linux is not horrible, but it is endlessly, relentlessly opaque an unhelpful. Linux assumes one's day job is linux and has no interest in any other possibility. Also, 10.6 Snow Leopard was the best version of MacOS, I will die on that hill. rant
5 minutes ago, Knuckledragger said:
Every experience with I have with Windows and now Linux is an argument for The Mac Tax FreeBSD.
FTFY
pkg install firefox
So apparently Pi Desktop is based on Debian Bullseye, which went EOL in August. That explains the 404s I've been getting trying to update it. The repositories are gone. My next step is to install Debian, probably with GNOME. The Linux Nightmare continues.
https://share.google/aimode/XuoXG0MBco66eDvJK
So as hardware is wont to do, a magic gremlin appeared between the Beelink and my gee whiz main display. It's a dual mode monitor that does 1080p @ WTF Hz (480 or something) and 4K at 180Hz. I run it in 1080p mode almost all the time. I began to get suspicious that the problem was hardware related, so I spent an hour integrating the Beelink into the shelf that hots the M4 mini and a bunch of other hardware. That meant dusting off and wiring up my trusty KVM switch. "KVM" is a misnomer in this day and age, but the function is the same. It has been my experience that newer (Silicon based) Mac are ...fussy about KVM switches. Fortunately, this one works with every device I have plugged into it. The downside is that KVM triples the number of wires. 😫 The Beelink is now getting along fine with the 2013 vintage 1200p Lenovo panel I use for system administration. Debian comes with FFX installed (yay!) I am too tired to pursue setting up Pihole tonight.
Also, a friend of mine who has been high up in the IT food chain for 25 years now (he is the DNS guy @ ADBE) also said, and I quote "Repeat after me. Net. BSD. Less gui bullshit." I will ignore him ...for the time being.
You should still be able to update to bookworm and then Trixie. But how did you even get such an old ISO?
That being said, if you have an amd64 computer, just use Debian.
Short answer: The Pihole dev team are still hosting it and not updating it. I only ended up having Pi OS desktop running for an afternoon. I've now got a fresh install of Debian 13 on the Beelink, connected to a monitor that it actually likes.
Also, last night, on a whim, I installed Unbuntu on a mid 2010 Mac Mini I bought from ...some Head-Caser or another years ago. It's got a sputtering Core 2 Duo, but it does have 16GB of RAM and a 512GB SSD. I think I'm going to use it to sing sea shanties.
Further update. At most turns, Ubuntu seems a bit more user. It has more useful things installed (it's also a much bigger installer, 3.4GB vs ~750MB.) The GNOME GUI is much nicer than ...whatever ships with Debian. Ubuntu gives you sudo access by default. On Debian I had to su and then enter a command I needed to google to add my account to the sudo list. Then I had to reboot log out and log in again. This might be no big deal for seasoned linux neckbeards users, but I had to learn and muddle through every step. Shout out to Proton VPN for being super Linux friendly. They have a whole page dedicated to installing their client, with easily copyable commands to make things go.
On the not so plus side, Ubuntu could connect to my M4 Mini server's file system easily. Thus far, Ubuntu has refused to. I need to install flatpk next...
I managed to get Docker installed on the Debian box. It only took a couple tries. The current problem I am having is getting Pihole installed with Docker. When I paste the command into console, I get an error about NTP (Network Time Protocol) not being installed. I'm still trying to figure out why I am getting that particular error. So far the search results have been conflicting.
Aslo, I own Ubuntu an apology. It was not the OS's fault that it could not connect to my M4 Mini file server. The M4 was being a bitch and refusing to play SMB with any non-Mac. A reboot of it later, and it's working fine. This means that the "old enough to get its learner's permit" mid-2010 Mini is actually a useful device. Given the current state of gestures broadly that's not a bad thing. I am actually considering installing Ubuntu on my other micro PC, which was my W11-based TV box ...until I decided I could no longer stand Windows for anything except for video games.
I have successfully gotten my M4 Mac Mini to play nice (via SMB) with at least one of my Wintendos and a pair of Linux boxes. This was a nontrivial exercise. I ended up using Claude AI. Clod is actually pretty helpful with persnickety geek tasks. The process was more or less an involved "turn it off and turn it back on again." So far I kind of like Unbuntu. I'm actually considering installing it on my UM350 micro PC. Debian has proven to be more of a challenge. It's not precisely unfriendly, but it expect more of the user. I'm going to ask Claude about the NTP error that has been plaguing me for over a week now.
