Hongshu EH-1 electrostatic headphones and EHA-1 amplifier
Hello head-cases! New here, new to electrostats. I searched, but found very little info on the Hongshu EH-1 electrostatic headphones. (There seems to be even less info elsewhere.) There is a brief positive mention by Spritzer here, and two pictures of the EHA-1 PCB posted by MLA here, followed by Professor Gilmore's deduction of a schematic immediately after in that same thread.
Did I overlook a thread, or posts? I would love to see a review or comparison, or some measurements, both for the headphones, and for the amplifier. Kevin Gilmore's comments on the EHA-1 amp do not sound overly positive, so I have also a few more specific questions regarding a step-up transformer adapter: I read here or elsewhere that the Lundahl LL1630pp transformers, used in reverse, are a) a bit low in gain (14.4 with both primaries -as secondaries- in series), and b) a bit anemic in their low frequency power handling. I usually listen at quite moderate levels, 70 to 75dB SPL or so, so I'm wondering whether the LL1630pp's would be just fine for my purposes, given that the EH-1 supposedly makes 100dB SPL out of 100V RMS signal, and the LL1630pp should still put out well over 100V at anything above 10Hz - if fed enough voltage by the amp, of course. (For the LL1630 properties I'm referring to Aokman's posts on head-fi, in particular the plot just below, and his Youtube videos as user whatcouldgowrong.)
Aokman's LL1630 frequency response plot:
Or would something like the LL9202 (again the push pull version, with minimal air gap) be a lot more suitable (higher step up ratio and larger core volume)? I'm under the impression, perhaps mistaken, that the LL1630 might actually be easier to handle for my low power class A amplifiers (TU-8900, Zenductor 2 and the like; my only 'regular' amp is a class D Loxjie A30).
Add-on question: would there be anything wrong with using the bias from the EHA-1 when feeding the headphones through the step-up transformers, i.e. making an adapter cable that combines the EHA-1 bias and the LL1630 left and right stator connections?
Sorry if this is getting a bit long for a first post, but this forum seems like a good location to ask about electrostats.
Added: forgot to link to ETC6849's post with the LL9202's on audiosciencereview.
Edited by Gruesome
added LL9202 link on asr
Greetings back to the icy and dark north Atlantic! While I appreciate the warm welcome with your trademark salty language (not unlike Zenmod's 'Fugly!' on diyaudio), the meaning of your comment is not immediately self-evident to a newcomer. Would you care to expand a bit? What's wrong with Aokman's step-up transformer measurements? I don't think he suggests to apply the 800V to any headphones. Also, leaving those measurements aside, any more comments on the EH-1, and/or the EHA-1, or my question regarding re-use of the EHA-1 bias with external step-up transformers? Do you (or anybody else) have suggestions besides the LL1630 and LL9202?
Here's a bit of advice. Don't join and immediately post. This is not a regular forum. You need to lurk for a good while, and find out who is who. I'm pretty sure you got a welcome message that makes this all clear.
psyduck, thanks a lot! I assume these are the gerber files for this thread: https://www.head-case.org/forums/topic/33077-finally-an-electrostatic-transportable/ That's very generous of Kevin Gilmore! I'm also quite intrigued by the deceivingly simple op-amp + silicon carbide FET combination in the first circuit on this website/page (it's Japanese, but the automatic translation in Google Chrome seems to be working well enough). Has this ('TAKA's SiC FET STAX driver' on Konton's website at https://www7b.biglobe.ne.jp/~konton/STAX%20SRIVER%20sono4.htm , from 2019 or thereabouts) maybe already been discussed somewhere here?
Craig, I appreciate it; no worries. Of course I've been reading quite a bit before posting. I'll keep an eye out for any official communications from the forum, but so far I just got email notifications for replies to this thread, and no private messages yet.
If no one has ripped you a new asshole yet, you're probably OK, but don't assume this place is your friendly neighborhood pub either, until to you get to know people.
That is just not true. You joined and then posted 9 hours later. Hardly "reading quite a bit"
And to say of one of the most serious list members on this forum with 14.7 thousand posts "I appreciate the warm welcome with your trademark salty language" shows you have less than zero knowledge of who is who. And how can you possibly know that Spritzer's reply is his "trademark"???????????
Pars sums it up perfectly.
