The Ultimate DIY Part 2 ? The KGITSOJC
That would be possible but pots are problematic.
  • Replies 350
  • Views 130.3k
  • kevin gilmore
    kevin gilmore
    Sure there is a schematic. Its in my head somewhere. There will be an official schematic at some point. There is a bunch of different ways to build it including single ended only, and balanced/sin
  • Has there been any work on this lately?  I really want to do this one.
  • Input JFETs just came in the mail. Most of them look real, there are a couple 2sk170s that have funky looking printing on them that I'm not sure about. Will measure IDSS later.    Finally the projec
so it turns out the hawksford already came up with the idea of cascading a current mirror (well sort of)
http://www.essex.ac.uk/csee/research/audio_lab/malcolmspubdocs/J10%20Enhanced%20cascode.pdf
it also turns out that the single ended version where you ground the input, and then drive the emitters
makes an absolutely wonderful I/V converter for your favorite dac.
also previously released in a simplified version by pedja rogic.
http://gilmore.chem.northwestern.edu/privstage.pdf
so the building blocks are now piling up.
need a really sweet output stage (not the headphone kind)
and this preamp should be able to compete with the big boys.
File not found Sent from my iPhone using Tapatalk
  • 3 months later...
I have not started on the board yet.
I wanted to get a few more things done first
Like the squarewave
Sounds good.  Now I just need to find a nice tube amp for speakers to run with it.
  • 3 months later...
It's the second coming, that's why.
well there is this
http://gilmore.chem.northwestern.edu/sqss1.jpg
I'm not going to finish the ultimate preamp till a reliable source of audio grade complementary jfets
is available. Too many fakes out there to design with old stuff, and linear systems is a bunch
of incompetent fucknuts. But I do have a working one on the bench. It has to be a jfet input otherwise
the input impedance is too low and the bipolar parts have too much offset with high impedance sources.
Seems like it never left the drawing board.
How about PMBFJ177? Or wait for LSJ74?
LSJ74 now is available to DIYers, except you can only get like 2 per person. i think next they'll be putting 1 FET in every box of raisin bran
 PMBFJ177  is equivalent to the piece of shit cavalli is using in his overpriced pieces of crap
and it sounds like absolute dogshit too.  designed for switching use. not for analog audio.
Changing from the J176 to tightly matched J74's was not a subtle change in the LL1.  All matched to identical specs...
Edited by spritzer
LSJ74 pricing
Grade A (Idss 2.6 - 6.5): 8 pieces $53.04 ($6.63 each)
Grade B (Idss 6 - 12): 8 pieces $50.16 ($6.27 each)
Grade C (Idss 10 - 20): 8 pieces $47.28 ($5.91 each)
Grade D (Idss 20 - 30): 8 pieces $47.28 ($5.91 each)
I bought some and the Idss is all over the place.  No way to get any matches from those 8.
i would match for Vgs at the circuit current
For this one then yes.  I was matching the Idss for the LL1 as that's how the stock units are matched.
Don, are they within the claimed range?
They are and if people would pool a number of purchases then I'm sure there are some nice matches to be found.  Personally I'd just wait until Linear fill those few million unit orders and these will be available in mass.
Hi !
Sorry for hijacking the tread ))
I check this tread and find only schematic for Vendetta - if i miss something -i am sorry.
Any chance to see the board picture for this phono stage clone - or even order one through the GB ?
I am quite interested to make this unit - heard a lot of good reviews of this one.
Thanks in advance
With  respect
Alex
