Toob amp for AE A5s?
With having the constant need to tinker I was thinking about bypassing the internal amp of the A5s with some sort of toob amp. I like way the A5s sound but I think the amp is possibly holding them back a bit. Plus at low volumes it puts more power to the left speaker than the right which is really annoying. I was thinking about picking up something like the Miniwatt N3. Any better suggestions?
I don't think much power since I am using these near field. The internal amp is rated at 50w with a peak of 75w per ch. I doubt it can do that much though. I think a solid 5-10w would be plenty with more always being better.
Edit: Yes it would be external. Also I figure since I already have these sitting here I might as well use them.
I figured you would say that. Enabler ;)
I t looks pretty do-able except I will will need some sort of pre-amp/volume control if I go that route.
I have a pair of balanced Luminous Audio passive volume controls that I can send. You can borrow them as long as you'd like, as I have no use for them in the foreseeable future.
High zin, so yeah, just wire a pot before the input.
Wasn't expecting to got that route but when an opportunity shows itself.....
Still doesn't mean I shouldn't build something. I do think I would like to build something that could accommodate a wide range of speakers.
300B FTW! You can use it with the K1K too.
