September 28, 201115 yr comment_471778 Ok, I have a quick question. So, I have some of these sockets, with brackets: I need to somehow embed a nut into the bracket, so I can then secure them to the top of the chassis. I won't have access to the bottom of the socket. I don't know much about PEM nuts, but I was wondering if something like that might work. I'm leary to try an adhesive, or soldering, etc. but maybe it might work, but I'd prefer a better solution. If someone wants to make me a bracket, that's a different story, but let's assume that's not a viable option either. Report
September 28, 201115 yr comment_471783 I'd say give captive nuts a try first. This is for the T2, right? Are you soldering the pins directly to the pcb or air wiring it? Report
September 28, 201115 yr Author comment_471786 It's not for a T2. I am soldering the pins to a PCB. How does one size a captive nut properly? Edited September 28, 201115 yr by luvdunhill Report
September 28, 201115 yr comment_471792 You'll have to ask kerry for the specifics, since he used them in his builds. But I'm guessing it's just picking the size of the head that will fit the mounting hole. Report
September 28, 201115 yr comment_471799 Use an epoxy to glue the nuts into place. A high temp stable one would be a good idea... jbweld would probably be fine =) Report
September 28, 201115 yr comment_471802 Can you put the bracket on the top of the socket and tap the hole in the chassis? You'd have to mount the socket first before connecting it to the PCB. Edited September 28, 201115 yr by dsavitsk Report
September 29, 201115 yr comment_471896 how about cutting a very thin lip on the end and folding that down onto the nut - possibly epoxy the flap and nut in place..dB Report
September 29, 201115 yr comment_472081 mikhail had a version that looked just like that, and did in fact fit the teflon sockets, and it was threaded. So go looking for some russian junk and you should be able to find them. Or spotweld the nuts onto the frame. Or use female threaded inserts of the right size, a star washer and a brass washer and solder to hold things in place. edit: i tried some pems nuts and they work great if you have the right size, and something to use as a bench press to put them in straight. Edited September 30, 201114 yr by kevin gilmore Report
