krell ksa5 klone
  • Replies 805
  • Views 363.9k
  • My Krell:
Nice. Does this amp require much if any matching of parts?
I think R20 (Pot) is 50ohm.
Sorry, you are right.
500R = 500ohm.
500 = 50ohm
Schematic:
Q2(Q7) Collector -  Q12(Q13)Base
Board:
Q3(Q8) Collector - Q12(Q13)Base
IN2 only (IN1 is OK)
Schematic:Q14,23&24 MJE15030
Board:MJE15031
Schematic:Q25&26 MJE15031
Board:MJE15030
+/-22V line (or +/- 21V?)
4.7uF/63V are not on the schematic
Q27 Collector
0.1uF is not on the schematic
Edited by Inu
Thanks, got all of them. Not sure yet about q27 collector cap.
The 4.7uf caps are at birgir's idea. (also kind of expensive)
evidently no amp is complete without some wima's.
will post again when i get home.
updated schematic and picture, have a look.
very pathetic BOM in progress
includes some of the power supply
1000uf 35v ls=5 dia=13mm 871-B41041A7108M000 35 0.47 16.45
.1uf 100v ls=5mm 80-R82EC3100DQ70J 14 0.32 4.48
4.7uf 63v wima 505-MKS24.7/63/5 7 4.33 30.31
470pf 500v  ls 5.9mm 5982-15-500V470 4 2.28 9.12
39pf 500v ls 5.9mm 598-CD17ED390JO3 2 1.35 2.7
220pf 500v ls 5.9mm  598-CD15FD221JO3F 2 1.22 2.44
220uf 50v ls 5mm dia 10mm 647-UPW1H221MPD 4 0.58 2.32
4700uf 50v ls10mm 35 dia 598-SLP472M050C5P3 2 3.2 6.4
mjf15030  6 1.63 9.78
mjf15031  4 1.63 6.52
heatsink amp board 513102b02500g 8 1 8
mpsa56  19 0.12 2.28
mpsa06  23 0.32 7.36
lsk389  2
relay 653-g5v-2-h1-dc24 2 2.76 5.52
op27 digikey 4 6.01 24.04
Its about $137 not including the resistors and some of the
other power supply components. So definitely under $250
with transformer and everything.
Unless you go very nuts on the resistors.
Zettler 24V Relay
A2830-2C-24DS
http://www.bgmicro.com/REL1086.aspx
MPS8099 and 8599 (0.15)
http://www.bgmicro.com/TRNMPS8099.aspx
http://www.bgmicro.com/TRNMPS8599.aspx
It is hard to pairing MJEs…    :-[
MJE15030G(NPN)
Lot:AFA50
hfe = 78 78 80 83 96 97 98 104 104 105 107 109 111 114
MJE15031G(PNP)
Lot: AFB09
hfe = 228 234 238 241 242 252 253 257 260 262
Edited by Inu
thanks Kevin and Bigir for this.  i'm in for a few boards.
The amp board is just about ready so I'll probably be ordering prototypes before Christmas.  :)
sweet!
what we need to do is find a massive stock of 1000uf/25v blackgate non-polarized caps.
The only place that has them in stock wants $80 each and we need 35 per board.
Soooo...for about 10x the price of the amp I could have it all Blackgated up? :blink: :blink:
Even if I wanted to go nuts with it, there is no way I could pull the trigger on that.
Yeah sane thing here.  I'll just stick with the Panasonic's and waste the rest of the money on the Megatron PCB heading my way... ;D
I still think Krell just had a few thousand of those CDE caps sitting there and decided to cram the amp full of them... :laugh:
  • 5 months later...
I just order all the components and the PCB to make one ::)
I will use Nichicon FG series for the 1000uF/35V condensators. Great value for the money... Not so good as the Blackgate or Elna Silmic II, but much cheaper !
I Let you know if the name of Krell is as great as it should be :indra:
I know the goal here is to clone the krell but I am curious ; would it work to split R15 and put an integrator's output in the middle, dynalo style ? Requires to modify the servo and get rid of C10, C18 and C19 ...
Some progress:
I didn't order the PSU boards as they were never 100% finalized.  A Sigma22 works just as fine for testing though.
Very cool spritzer! I'm definitely looking forward to seeing how they work out  :D
