krell ksa5 klone
  • Replies 805
  • Views 375.3k
  • My Krell:
Very nice!
I can see this project in my future :)
Edited by Kerry
Almost finished the amp, and waiting on a Mouser order for P/S parts.
Edited by fordgtlover
My zener power supply is up and running and temporarily cased. I couldn't find a 27V transformer so I've used a 25V one, which results in an output voltage of the power supply at ~20.5v. Is using a 25v transformer a problem?
That is right depending on the second stage zeners.
If unreg voltage is at least 35 you will be fine
not yet.  i'm contacting Richard on Mon.  27V/50VA i'm guessing will be around $50-60 + shipping.  i'll let you know.
no 4.7uF Wima from Mouser until mid Dec.  may try to parallel 3.3uF and 1uF with the latter mounted perpendicular/flush underneath the pcb.
Edited by fishski13
You can try the Wima distributor instead.  They sell small lots.
thanks Bigir.
i have a bunch of 50V 4.7uF Wimas in the parts bin with 5mm pitch.  any issues going with a lower VDC rating?  since we're looking at decoupling rails of 21V and compensation on the DC servo, 50VDC should be safe?
Wandered over from some of the other forums....this build caught my eye. Nice! :)
Thinking about doing one....
Here is a you tube video some one made for a ebay sale of a KSA-5 in 2011.
Edited by bozebuttons
When you are trying to sell a used 20 year old amp for $5k what do you
Expect. It is a great amp but not for very low sensitivity headphones
I've got some PMs out to try and get a board set (lil knight). Any other leads would be appreciated. Looks like this is going to be a cool build. :)
I may go that route, but figured I'd try to get on someone else's run to help keep everyone's costs down. Is there a suggested service that has successfully done a run with these files? Thanks for the reply!
All board files are available if you want t have boards made
Www.pcbnet.com
amp board is 10 x 7.5 inches 609 holes
10 boards from pcbnet.com would be $425
3 oz copper
