krell ksa5 klone
  • Replies 805
  • Views 362.1k
  • My Krell:
Very nice!
I can see this project in my future :)
Edited by Kerry
I want a collection of audio company branded transistors. That would be awesome wall art.
Almost finished the amp, and waiting on a Mouser order for P/S parts.
Edited by fordgtlover
My zener power supply is up and running and temporarily cased. I couldn't find a 27V transformer so I've used a 25V one, which results in an output voltage of the power supply at ~20.5v. Is using a 25v transformer a problem?
That is right depending on the second stage zeners.
If unreg voltage is at least 35 you will be fine
looking good ford.  i'm placing orders next week along with a TX from SumR.
Cheers. Do you have a cost on the TX?
not yet.  i'm contacting Richard on Mon.  27V/50VA i'm guessing will be around $50-60 + shipping.  i'll let you know.
no 4.7uF Wima from Mouser until mid Dec.  may try to parallel 3.3uF and 1uF with the latter mounted perpendicular/flush underneath the pcb.
Edited by fishski13
You can try the Wima distributor instead.  They sell small lots.
thanks Bigir.
i have a bunch of 50V 4.7uF Wimas in the parts bin with 5mm pitch.  any issues going with a lower VDC rating?  since we're looking at decoupling rails of 21V and compensation on the DC servo, 50VDC should be safe?
great.
i went ahead and ordered a SumR  2 x 27V/50VA at $54.
Wandered over from some of the other forums....this build caught my eye. Nice! :)
Thinking about doing one....
Here is a you tube video some one made for a ebay sale of a KSA-5 in 2011.
Edited by bozebuttons
Wow, that's.... ehhh... quite dramatic.
When you are trying to sell a used 20 year old amp for $5k what do you
Expect. It is a great amp but not for very low sensitivity headphones
I've got some PMs out to try and get a board set (lil knight). Any other leads would be appreciated. Looks like this is going to be a cool build. :)
I may go that route, but figured I'd try to get on someone else's run to help keep everyone's costs down. Is there a suggested service that has successfully done a run with these files? Thanks for the reply!
All board files are available if you want t have boards made
Www.pcbnet.com
amp board is 10 x 7.5 inches 609 holes
10 boards from pcbnet.com would be $425
3 oz copper
