My zener power supply is up and running and temporarily cased. I couldn't find a 27V transformer so I've used a 25V one, which results in an output voltage of the power supply at ~20.5v. Is using a 25v transformer a problem?
not yet.  i'm contacting Richard on Mon.  27V/50VA i'm guessing will be around $50-60 + shipping.  i'll let you know.
no 4.7uF Wima from Mouser until mid Dec.  may try to parallel 3.3uF and 1uF with the latter mounted perpendicular/flush underneath the pcb.
Edited by fishski13
thanks Bigir.
i have a bunch of 50V 4.7uF Wimas in the parts bin with 5mm pitch.  any issues going with a lower VDC rating?  since we're looking at decoupling rails of 21V and compensation on the DC servo, 50VDC should be safe?
I may go that route, but figured I'd try to get on someone else's run to help keep everyone's costs down. Is there a suggested service that has successfully done a run with these files? Thanks for the reply!
All board files are available if you want t have boards made
