November 25, 201313 yr comment_611196 A few years ago JMoney Audio was going to produce HE90 headband/earpads in leather but it never came to fruition. Has anyone ever produced these in leather, or does anyone have a source for Sennheiser originals; specifically headband pad? When I checked a couple years ago Sennheiser no longer had these available and it seems JMoney gave up on the project. Sorry if this sounds silly but I've been out of the loop for a while, so any info is appreciated. Gary Report
November 25, 201313 yr comment_611208 Gary I'm not sure where to get these but the Stax crew here might Edited November 25, 201313 yr by jp11801 Report
November 26, 201313 yr Author comment_611213 Thanks John, just wanted to check over here but after checking again over at Head-Fi I'm not so sure this is possible. Report
November 26, 201313 yr comment_611275 I bought a headpad via the Icelandic distributor not that long ago and I can go in a check if they can order more. Report
November 26, 201313 yr comment_611305 I can help out as well. Normally they are backed order but should still be available. Let me know. Report
November 27, 201313 yr Author comment_611394 Sorry I couldn't respond sooner guys and thanks a lot. I'll PM you, Gary. Report
November 27, 201313 yr comment_611400 Dwight at Senn told me I bought the last ones in Senn USA stock, but that was 6 months ago. He had to order for another person from Senn Germany. You could always DIY your own leather versions. Reuse the retention rings and foam Report
November 27, 201313 yr comment_611408 Dwight at Senn told me I bought the last ones in Senn USA stock, but that was 6 months ago. He had to order for another person from Senn Germany. You could always DIY your own leather versions. Reuse the retention rings and foam The stock may have ran out but it should still be available from Senn Germany. I would check with Dwight Stevenson again. His number is (860)-434-9190 ext. 136. He is super helpful and a real pleasure to talk to. Report
November 27, 201313 yr comment_611417 Jan Meier might have an "in" on the German side. He's usually pretty responsive to emails. Report
November 27, 201313 yr comment_611431 I know they either had to dig some more out of storage or make some more recently. The software used by Senn showed no stock in Germany... Report
November 28, 201313 yr Author comment_611544 I'll call Dwight after the holiday and go from there. Appreciate all the responses, thanks. Gary Report
August 21, 201412 yr Author comment_649479 Just FYI, as of about 2 month ago Senn USA does have these pads in stock if anyone is interested. The headband pads have gone up to $44 and the ear pads are now $195. Report
