New mix...
mix grams
rye 200
slept 100
whole 200
AP 500
h20 850
leaven 200
salt 35
bake:
covered 500 20 min
covered 450 10 min
uncover 25min
M Marks the Loaf (just baking the second loaf)
Edited by mikeymad
Old mix -
Mix grams
whole 100
AP 900
h20 750
leaven 200
salt 28
bake:
covered 500 20 min
covered 450 10 min
uncover 25min
and crumb
Second loaf stuck to the proofing towel - hence the roman helmet...look...  and didn't rise much.
But the crumb was good and it was tasty...
Edited by mikeymad
It is my homage to the dog...
but there is a scary creature that it reminds me of now... (could not find it)
That is the hope Al - went back to basics, and then will try different things to see what might bring them back..
First Bake in new house and new oven... -- so far so good...
Mix - grams
Oat Flour - 250
whole wheat - 250
All Purpose - 500
h20 - 750
leaven - 200
salt - 30
bake:
covered 500 20 min
covered 450 10 min
uncover 20 min
(ed - like the crumb too)
Edited by mikeymad
  • Like 1
  • 4 weeks later...
Late Bake -
Trying some longer fermentation and rise times. This with a larger 650g of flour rye bread.  With the higher Hydration may need a little bit longer bake to get some of the water out and to cook the bigger loaf.
Mix - grams
Rye Flour - 65g
whole wheat - 195g
All Purpose - 390g
h20 - 520g
leaven - 100g
salt - 16g
bake:
covered 500 20 min
covered 450 20 min
uncover 15 min
I like the results - will look forward to when it is cooler.
  • Like 2
Thanks Al,  I really liked that one - The longer fermentation time gave it a lovely sour tang.
I made two more from the leftover leaven.  One worked out and the other was much more of an experiment.
I was using new flour so I wanted to make a standard loaf to test how it does (this is with Red Mill)
Mix - grams
whole wheat - 60g
All Purpose - 540g
h20 - 450g
leaven - 100g
salt - 15g
bake:
covered 500 20 min
covered 450 20 min
uncover 15 min
Since it had super long fermentation of the leaven (almost 24 hours) and an overnight (outside) proof of the final dough, it developed a lot of flavor from a basic white loaf.
I don't think that it can be a result of too much salt. If you are using commercial yeast, I think that this is a common issue. They are so active that they eat up all the food and the loaf can collapse, if the gluten structure is not strong (salt can help that too). More salt will help slow down the proofing process so that you can get a longer rise. With the wild yeast that I am using it takes a long time to get going anyway. So I would say more salt is your friend.
With longer rise times, I often get a collapsed loaf.  Am I not using enough salt, too much or something else?
It's likely rising too much so not enough salt.  The golden rule is 30gr per 1L of water.  You can go up to 40gr for more flavor but also slower rise time.
Edited by spritzer
