October 23, 20188 yr comment_796965 Interesting, I thought it would be the other way around where big players got the preferential treatment from parts manufacturers. Plus the economic of scale where they could produce at lower cost than DIY builders. Maybe it will be offset later for dealers margin but still they should be able to produce something with the same performance level. And while Birgir is here, hypothetically if one day Stax oyabuns have a change of heart and decides to put out true performance product, and they decide that the easiest way would be to use the existing DIY design like Carbons, how difficult it would be for the product to see the actual launch? Report
October 23, 20188 yr comment_796966 Although Stax bought thousands of semiconductors, its demand is not comparable to a real giants of the industry. It probably does not economically compensate to produce old sand only because a small manufacturer needs a few thousand devices. I doubt that Stax adopts a circuit that has not been designed by themselves. I suppose it's a question of being proud. Report
October 23, 20188 yr Author comment_796976 They do manage large savings across the board by basically using the same chassis design for almost 40 years with minimal changes but they also really lag behind in modernizing how this stuff is built. Now full SMD is tricky at these voltage levels but system integration and having less wiring will make a real difference to the assembly time for each unit. As for the circuits, they could build a variation of the Carbon but they have a real reluctance to use certain parts or for the amps to weigh too much. Both would apply to the Carbon as it needs large heatsinks to function properly. Now you could scale back the power but sort of defeats the point of all of this... Report
November 6, 20188 yr comment_797642 As I've said before, I am surprised that they didn't make the T8000 an updated T1 by substituting constant current loads for the resistors - it's an easy and obvious switch that brings it up to current standards. They already have a constant current load circuit in their solid state designs, and it's not as if the T1 is a purely tube design that can't be "polluted" with solid state elements. Edited November 6, 20188 yr by JimL Report
November 6, 20188 yr Author comment_797647 The T8000 reeks of desperation to me more than anything. For them, there were no HV transistors left and no dual fet inputs so they needed to work around that. They did it badly and it is in no way a high end amp. Report
November 11, 20188 yr comment_797915 I always think that every company that work on a niche market would benefit from a halo product. Something that pushes the boundary. Something that most of its fans could only aspire to have someday. Well, at least they still haven't use the SRM-T3 name yet.. Report
November 11, 20188 yr Author comment_797929 Halo products are great...if they are actually great. The issue now is that looks and useless crap matter more than anything else. Report
July 12, 20206 yr comment_831167 I know it may sound stupid but can you give me more hints on how to change the voltage for t8000? I want to change from 120v to 220v. Also, should I need to chage fuze after changing voltage? maybe I need to rewire some lines in the picture but don't know what exactly should do. Report
July 13, 20206 yr comment_831295 warning: check with ohmmeter to make sure the transformer is wired like all other stax transformers for 100v jumpers at J1,J3,J4 grey to white green to brn remove other jumpers for 120v jumpers at J2,J3,J5 grey to white purple to blue remove other jumpers for 220v jumpers at J5,J6 blue gry to purple remove other jumpers white ties to yellow thru fuse white,green,purple is one winding 0,100v,120v grey,brown.blue is other winding 0.100v.120v Edited July 13, 20206 yr by kevin gilmore Report
September 15, 20224 yr comment_893503 On 11/6/2018 at 2:34 PM, spritzer said: The T8000 reeks of desperation to me more than anything. For them, there were no HV transistors left and no dual fet inputs so they needed to work around that. They did it badly and it is in no way a high end amp. Have you experimented and figured out how to tweak it and un-fuck the sound? Report
September 15, 20224 yr Author comment_893505 Nope, no way to do that and with roughly 40% failure rate, no way I'm ever touching one of them again. Report
September 16, 20224 yr Author comment_893562 Not sure, ones been sitting unsold in Japan for weeks for just over 3k$. Report
September 16, 20224 yr comment_893565 Well, fuck😒 At least I'll have my BHSE soon. Edited September 16, 20224 yr by randerson3024 Report
September 16, 20224 yr comment_893574 This year, the two last ones on HF sold for 4000$ and 3500$ respectively (maybe a bit less) Report
September 1, 20242 yr Author comment_942856 Now after only 7+ years of the T8000 being a fairly shitty amp... Stax have made extra input boards for them. No word on pricing yet but yeah... who fucking cares Edited September 1, 20242 yr by spritzer Report
