Stax SRM-T8000
Interesting, I thought it would be the other way around where big players got the preferential treatment from parts manufacturers. Plus the economic of scale where they could produce at lower cost than DIY builders. Maybe it will be offset later for dealers margin but still they should be able to produce something with the same performance level.
And while Birgir is here, hypothetically if one day Stax oyabuns have a change of heart and decides to put out true performance product, and they decide that the easiest way would be to use the existing DIY design like Carbons, how difficult it would be for the product to see the actual launch?
  • Replies 91
  • Views 57.9k
  • kevin gilmore
    kevin gilmore
    The 323 had a p-channel jfet as the input, +/-350v power supplies, 2sa1968 as the current source for the drivers etc. The 353 is a srm717 with all of the extra transistors removed. Very similar t
  • Now after only 7+ years of the T8000 being a fairly shitty amp... Stax have made extra input boards for them.  No word on pricing yet but yeah... who fucking cares
  • kevin gilmore
    kevin gilmore
    well they are more annoyed by birgir's comments. i'm slightly more politically correct. (when I wanna be)
Although Stax bought thousands of semiconductors, its demand is not comparable to a real giants of the industry. It probably does not economically compensate to produce old sand only because a small manufacturer needs a few thousand devices.
I doubt that Stax adopts a circuit that has not been designed by themselves. I suppose it's a question of being proud.
They do manage large savings across the board by basically using the same chassis design for almost 40 years with minimal changes but they also really lag behind in modernizing how this stuff is built.  Now full SMD is tricky at these voltage levels but system integration and having less wiring will make a real difference to the assembly time for each unit.
As for the circuits, they could build a variation of the Carbon but they have a real reluctance to use certain parts or for the amps to weigh too much.  Both would apply to the Carbon as it needs large heatsinks to function properly.  Now you could scale back the power but sort of defeats the point of all of this...
As I've said before, I am surprised that they didn't make the T8000 an updated T1 by substituting constant current loads for the resistors - it's an easy and obvious switch that brings it up to current standards. They already have a constant current load circuit in their solid state designs, and it's not as if the T1 is a purely tube design that can't be "polluted" with solid state elements.
Edited by JimL
The T8000 reeks of desperation to me more than anything.  For them, there were no HV transistors left and no dual fet inputs so they needed to work around that.  They did it badly and it is in no way a high end amp.
I always think that every company that work on a niche market would benefit from a halo product. Something that pushes the boundary. Something that most of its fans could only aspire to have someday.
Well, at least they still haven't use the SRM-T3 name yet..
Halo products are great...if they are actually great.  :)  The issue now is that looks and useless crap matter more than anything else.
  • 1 year later...
I know it may sound stupid but can you give me more hints on how to change the voltage for t8000?
I want to change from 120v to 220v. Also, should I need to chage fuze after changing voltage?
maybe I need to rewire some lines in the picture but don't know what exactly should do.
warning: check with ohmmeter to make sure the transformer is wired like all other stax transformers
for 100v   jumpers at J1,J3,J4     grey to white   green to brn  remove other jumpers
for 120v   jumpers at J2,J3,J5    grey to white   purple to blue remove other jumpers
for 220v   jumpers at  J5,J6        blue    gry to purple remove other jumpers
white ties to yellow thru fuse
white,green,purple is one winding 0,100v,120v
grey,brown.blue is other winding  0.100v.120v
  • 2 years later...
Have you experimented and figured out how to tweak it and un-fuck the sound?
Nope, no way to do that and with roughly 40% failure rate, no way I'm ever touching one of them again.
Not sure, ones been sitting unsold in Japan for weeks for just over 3k$.
This year, the two last ones on HF sold for 4000$ and 3500$ respectively (maybe a bit less)
  • 1 year later...
Edited by spritzer
