Balanced amp on the cheap - suggestions anyone?
Well played, I liked the way you worked that in.
Rofl. :kitty:
  • Replies 53
  • Views 10.7k
Uh, 850$ is such a little bit more then the 300$ I would have been able to spend, so I think I will pass this one...
And then there is the question of 110V vs 220V..
But thanks anyway, any other suggestions?
... any other suggestions?
Have you considered the DIY route? I'm planning to get started on my first balanced amp in a week or two. It'll be a Dynamid (more info, PCBs, build guide here: http://www.djgardner.com/headphone/gilmore/) running off a pair of STEPS power supplies. I have the STEPS power supplies built and ready and in the morning, will put in the orders for everything else so I can stuff them over the long weekend.
I've built a Dynalo and the build is mostly painless. Think I have about $130 into the power supplies and it'll be another $150 or so for the amps. You can repurpose another case to go the cheap route with enclosures, but I'll probably drop another $100 or so there. If you're careful and re-use something from a thrift store, you should be able to piece one together around $300.
You can balance other designs, as well, but this one comes in around your budget and should be a keeper. If the Dynalo is anything to judge by, the Dynamid should be excellent.
