July 23, 200818 yr So I bought the Mini3 that jinp6301 sold and the battery life's been pretty bad. I get about 3 hours per charge, so I figure it's time to replace the 9v that came with it. Any recommendations as to which 9v I should use?
July 23, 200818 yr *cough* mini^3 isint the same as an m^3 dude and hmm, I used to get about 6 hours usually
July 23, 200818 yr It might not have that high a capacity 9V in it and it might depend on what headphones he is using.
July 23, 200818 yr Author I'm using im716's. I don't know what kind of 9V is in there right now, I'm guessing whatever came with it, and from my recollection, jinp bought it from boomana, who said it was a rockhopper mini3? So from his website, it's a 300mah 9V. And yes, it is the high performance version.
July 23, 200818 yr Author I was mainly asking if you guys would recommend any 9V over another. I know you guys have had more experience than me (never use 9V except for an alarm clock).
July 23, 200818 yr Author Sounds good to me. I'll get a pair on my way home today and will let let you guys know in a day or two if it fixed the problem.
July 23, 200818 yr If you buy radioshack rechargeables they won't fit in the case...if i remember correctly, it's a bit of a tight fit i think.
July 23, 200818 yr Well, It's been awhile since I used them, but I seem to recall them not fitting well, I think I still have some at home, I can check tonight.
July 23, 200818 yr Author Thanks for the info. If you can check, that would be great. I'll wait until you respond sicne I can always to go RS tomorrow.
