September 5, 201016 yr comment_385771 First things first. Then i will read upward later. First things first - welcome back! The power supply problem is fixed. Verified by Inu. Took about 5 tries I've done the mod, board bolted to heasinks, just wiring in the transformers. Hopefully later today this puppy will get fired up. Report
September 5, 201016 yr comment_385777 Welcome back =) From my "2 second before bed" scan of the schematic it looks like just the 4 x .1uf caps? Nice!~ Report
September 5, 201016 yr comment_385780 Welcome back =) From my "2 second before bed" scan of the schematic it looks like just the 4 x .1uf caps? Nice!~ Plus the 10k resistor between the voltage reference and pin 2 of the OP27. Report
September 5, 201016 yr comment_385788 Is this change applicable to all four supplies? So I understand from KG - so that is what I've done. I think he's updated the PSU schematic to include all this stuff - usual link. Took more than half an hour to find my 1/4" crimp receptacles. Aagh. Report
September 5, 201016 yr comment_385879 Plus the 10k resistor between the voltage reference and pin 2 of the OP27. Oops dunno how I missed that. Report
September 5, 201016 yr comment_385880 Oops dunno how I missed that. . Too early in the day here in Aus. Report
September 5, 201016 yr comment_385901 The resistor may not be necessary as the output impedance of the reference is about 1k. In which case the cap would need to be 1uf. I have not tried this. Also instead of cutting a trace, you can put the reference up on a pair of sockets stacked together with the resistor in the middle. Picture on this at some point. Report
September 6, 201016 yr comment_385921 I have finally figured out the discrepancy in my spice simulator on the power supply vs ltspice. Although they still don't entirely agree. The explanation would take 3 or 4 pages, so i'll omit that. Back to the 20 year old software. Report
September 6, 201016 yr comment_385976 Whohoa! Power supply lives. Just went for broke, screwed the whole shebang into the casework, wired it up and turned it on. Unloaded volts are just about bang on. Haven't checked for ripple yet Now the question is - do I dummy load it, or just go for broke and build the amp up? Report
September 6, 201016 yr comment_386042 Geez - I've just spent five hours (a) fitting the DACT and ( fitting half the transistors to the heatsinks (just the 20-off c3675's). Gotta get it more or less finished tomorrow - wife and daughter have gone to Rhodes (I hate hot holidays; I'm a cool climate guy) so I've been using the week as play time. They come back Wednesday, and will expect to find the house not looking like an electronics production shop floor. Report
September 6, 201016 yr comment_386098 I say wire it up and go nuts. Dummy load shmummy load =P Report
September 7, 201016 yr comment_386209 here Craig, use this: ?? On other topics, I was merrily torquing down the devices on the amp board, with the torque screwdriver set to the correct value of 1.1Nm for TO220 packages. I then moved on to the 2SA1486's - and promptly split the first one in two. Then I checked - the maximum torque for a TO126 package is 0.4Nm, and use of a washer under the screw head is recommended to further spread the load. Taking those remedial actions all is OK. By the way, I have gone back to using steel screws, but with the Aavid 7721-3PPSG bushes. These have a 3.18mm (1/8") shaft, which goes pretty much all the way through the 4171G ceramic insulators. The steel screws mean that you can get the torque set for maximum heat transfer (with heatsink grease too of course). The 7721-3PPSG is a slip-fit in some device holes and a tight interference fit in others - tolerance stack up I guess. Also, they cannot be used for metric screws because the hole is not quite big enough - so for that insulating bush those of us in metric countries need to get hold of the imperial 4/40 screws and nuts specified in the BOM. What I am doing with the 2SA1468's is to put a 4.7mm length of heatshrink over the threads of the 4/40 screws. This makes a nice fit in the device hole. 4.7mm goes most of the way through the ceramic insulator. Report
September 7, 201016 yr comment_386231 ?? http://www.head-case.org/forums/do-yourself/6925-ultimate-diy-stax-srm-t2-57.html#post369734 Report
September 7, 201016 yr comment_386233 What I am doing with the 2SA1468's is to put a 4.7mm length of heatshrink over the threads of the 4/40 screws. This makes a nice fit in the device hole. 4.7mm goes most of the way through the ceramic insulator. this seems totally unnecessary to me. It's a plastic package after all, why are you using ceramic insulators again? Report
September 7, 201016 yr Author comment_386254 Here I was thinking Marc had finally lost it, worrying about how fuses sound etc... Report
September 7, 201016 yr comment_386259 this seems totally unnecessary to me. It's a plastic package after all, why are you using ceramic insulators again? It may be a plastic package on that part, but its not insulated, collector is on the bottom. Report
September 7, 201016 yr comment_386279 http://www.head-case.org/forums/do-yourself/6925-ultimate-diy-stax-srm-t2-57.html#post369734 Goddit! Report
September 7, 201016 yr comment_386374 power supply fix pictures courtesy of Inu http://gilmore.chem.northwestern.edu/noise%20fix1.jpg http://gilmore.chem.northwestern.edu/noise%20fix2.jpg But if you don't want to cut the land, you can put the ref chip up on a pair of sockets with a resistor in the middle. Picture on that later. Report
September 7, 201016 yr comment_386386 Just the Amphenols to wire up now http://www.tech-enterprise.com/tekstuff/P9070512.JPG http://www.tech-enterprise.com/tekstuff/P9070513.JPG Report
September 7, 201016 yr comment_386427 Hehe I take it work on the bh is on hold? Ah - you spotted that lurking in the background Report
September 7, 201016 yr comment_386429 For those interested here are the prices. It really only makes sense if i do another 20 piece board run. power supply board quantity 5 $157 each quantity 10 $97 each quantity 20 $61 each amp board quantity 5 $242 each quantity 10 $166 each quantity 20 $102 each so prices did go up ever so slightly due to increase in sales tax. which makes a set of boards quantity 5 $399 quantity 10 $263 quantity 20 $163 Report
