The Ultimate DIY Part 2 ? The KGITSOJC
I know I asked this a while back, but what are you thinking of doing for the power supply Kevin? You thinking of tailoring something for this specific build, or do we just come up with our own solution (ie, o22)?
Edited by Horio
  • Replies 350
  • Views 128.6k
  • kevin gilmore
    kevin gilmore
    Sure there is a schematic. Its in my head somewhere. There will be an official schematic at some point. There is a bunch of different ways to build it including single ended only, and balanced/sin
  • Has there been any work on this lately?  I really want to do this one.
  • Input JFETs just came in the mail. Most of them look real, there are a couple 2sk170s that have funky looking printing on them that I'm not sure about. Will measure IDSS later.    Finally the projec
Have not even thought about the power supply yet. In the simplest version the
smallest power one tripple works great. If you go with the outboard amplifier modules
then you need something that does +/-20, then you can regulate that down to +/-15 with
simple 3 terminal regulators, and +12 to drive the relays.
Do you have a rough idea what the current draw is for the various voltages? Seems like the 12V line is going to be very small, but the 5V line might see some current with the Arduino. I have no idea what the +/-20V and +/-15V might see though.
Edited by Horio
Fully loaded, on the 20v lines about 500ma
On the 15v lines about 250 ma
12v line peaks of 30 ma
5v line I gotta look up
  • 4 weeks later...
How is the progress coming along? Is the testing going well?
Kerry still messing with the multi amp
I'm waiting on hopefully final preamp boards
I was out on vacation and came back to a ton of work. I'll have some time to finish playing with the servos next week and hopefully we'll be good.
  • 4 weeks later...
single ended only, and balanced/single ended
The on board buffer which you don't have to use is
an lme49710 driving an lme49600 closed loop with
a tl071 as the servo, optionally the lt1150.
The onboard single ended to balanced is an opa1632
with a tl071 servo. you don't have to use that either.
multiamp works for both. Single ended there are
x1 buffer opamps.
Clear as mud right?
There are a couple of people on amb's forum that think i have
sold out to ic's... But they should hear the thing. Just about
impossible to tell between the chips and the multiamp.
They've been making good progress on the display front for the raspberry pi:
Kerry,
How is the testing of the multi-amp boards going? Just curious.
I just finished reading through this thread and want to build one of these. I will definitely be on the lookout for the boards when they become available. Thank you KG.
Anything new going down, on the KGITSOJC front?
I've been out-of-pocket a bit on a new consulting gig and traveling as well. Will get to the multiamp next week. Just playing with the servos at this point. I've built it with the THAT bjt's but I'll try the jfets just to make sure.
Sweet! Looking forward to hearing your findings Kerry.
  • 4 weeks later...
Kerry, have you had a chance to play around with the multiamp boards at all or does the new job still have you swamped?
Has there been any progress on this? After the T2, I'm hoping this will be my next big project.
here is another one i like, buildable with currently available parts
http://gilmore.chem.northwestern.edu/fcnf.pdf
input can handle 10 volts peak to peak, its another operational transconductance amp.
input can also handle 2 volts of common mode or differential mode offset with 0 volts
dc output, something just about no other circuit can do. No feedback, and distortion
approaching .01%.  Flat to about 500khz.
Needs +/-45 volt power supplies, and plenty of heatsinks.
Otherwise cheap to build.  Add a unity gain output buffer (2 of them) and set the
gain with 2 resistors (or a 3 position switch) and a constant impedance attenuator
and have something very slick.
at what load?
