August 5, 201015 yr This is the message on the console: Java Plug-in 1.6.0_21 Using JRE version 1.6.0_21-b07 Java HotSpot Client VM User home directory = C:\Users\Alex ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage o: trigger logging q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack x: clear classloader cache 0-5: set trace level to <n> ---------------------------------------------------- AddonChat v8.60.00.09 [en, ico:0] Copyright
August 5, 201015 yr Also... maybe you want to try different browsers, update java, or... well... mess with the firewall. This chat is finicky at times. **BRENT**
August 5, 201015 yr Author Thanks. Indeed, someone had messed with the settings. I missed you all.. except that whore Brent.
August 5, 201015 yr uninstall jre. reinstall jre. given that it doesnt work right now it might be worth a try.
August 5, 201015 yr Default I can't chat with any of you due to Java error You make that sound like a bad thing.
