Blue Hawaii Special Edition
  • Replies 1.5k
  • Views 419.6k
  • luvdunhill
    luvdunhill
26 minutes ago, Craig Sawyers said:
Yes that is what I meant.
Oh, yeah. Right. I recall that in some thread (DIY?) on this forum, the guys encountered something similar. Many thanks! I'll check it out!
That said, of course, if Justin shares his thoughts, I would greatly appreciate it. :)
Unplug the headphone when they noise is present and don't touch the pins... is the noise still there?  It does sound a lot like the drivers are damaged in the headphones.
spritzer, thank you for your participation!
The hissing comes regardless of whether the headphones are plugged in or not.  There was no hissing at one time (e.g. yesterday), and then again today. That is, the issue occurs often, but not always.
The hissing is definitely coming from the amplifier. Not from the headphones.
Obviously, I need to open the bottom cover of the amplifier and take a look with my own eyes. I'm just trying to gather more information now about what I should pay attention to.
  • 3 months later...
I am now in my fourth month of using the amp. The hissing went away 2 weeks ago. All by itself. Completely. Either the warming up was completed, or a miracle happened. Don't know. But I'm glad :)
  • 1 year later...
Hey guys, I haven’t posted here in a good while. I’m glad that the forum is still alive. 😀
Does anyone have experience comparing the BHSE with KGST? I am kind of in the market for e-stat (specifically for the Audeze CRBN, I’m really surprised with how much I like them). I planned to order KGST from Birgir but a second hand BHSE popped up in our local market at around the same price.
Not many e-stat gears are circulating around nowadays so I have no choice but to blind buy.
Edited by K3cT
Well, buying used is always an option, but you then run the risk of parts may need replacing, depending on age use, etc..  A new amp should give you more peace of mind.  What does the BHSE offer over the KGST?  I have listened to a couple of headphones on a BHSE, and I can say it is a great amp.   I have also listened to the Carbon CC, which is an outstanding amp as well.  I have yet to listen to any of the KG series and would love to compare them to some of the others I have listened to.
