transconductance amp
so tyll has been going crazy over the bakoon for planars.
well there are a lot of things i don't like about that amp, especially the battery power and distortion.
so here is something much better, tested last night at .06%thd, no feedback, output impedance 100k which is solely due to the servo...
http://gilmore.chem.northwestern.edu/currentsourceamp2.pdf
http://gilmore.chem.northwestern.edu/currentsourceamp2.zip
also testing curved traces:P
  • Replies 112
  • Views 40.1k
  • Squeezed this amp into a small Modushop case. Tight fit for the caps, but it works. Doesn't get particularly warm. An interesting alternative for planars.
  • I forget to hang some photos of this amplifier. Sorry, I did not have any GRLV at that time ready.
  • kevin gilmore
    kevin gilmore
    http://gilmore.chem.northwestern.edu/currentamps.jpg
Nice! This is really interesting. I'm going to have to add it to the list.
That's really cool! Kind of looks like an AD844.
Would the cascode (Q1/Q2) be happier with more voltage drop than D1? The BC546/556 have some weird curves and don't saturate as quickly as something like the BC337/327.
Well, not really crazy about the Bakoon as much as I am intrigued by current source amps and how they might provide benefits over voltage amps.
Glad to see you working on it, Kevin.  I'll get you those measurements you want within a day or two.
change the high gain resistor to 75 ohms and the low gain resistor to 450 ohms to atch the gain of the bakoon
this is a bit higher than i thought
Pics or it didn't happen! B)
//UFN
I built the CFA2 a while back and am very happy with it, its great for the HE-500 I have, and works really well with the loaner planars I've managed to test it with (PM2, LCD-X).
Guess I have to build this one as well and compare :)  Any major differences to be expected in performance?
Edited by MLA
for planar ortho's with an impedance of 50 ohms,this amp really shines. with 30V supplies, does 2 watts pure class A into 50 ohms with a thd of about .03% which is much better than the bakoon does.
for hd800, all it does is accentuate the frequency response issues.
Sounds exactly like what I need!
If powering this from GRLV, what components other than the opamps need higher voltage rating to stay intact at 30V?
Great, thanks!!!
Is this amp able to drive desktop speakers?
2 Watts RMS into 50 ohms and you expect it to drive desktop speakers... NO
klipsch corner horns, probably ok.  not really desktop speakers
much more powerful amp coming at some point
What's up with people thinking that any headphone amp will work at driving speakers?  Some will output sound but that's about it.
//UFN
https://mightytext.net/zPRzoM
I have no privileges here to store Images and Google drive doesn't seem to work. so trying that  link...
Also on other site... under my profile are pictures, also not much to see as they are not pretty, but they do work.
I use an homemade CNC to route boards.
I completely agree, Its a Great amp.
Isn't it about output impedance / the dampening ratio? as well as wattage.....
My Firstwatt F5 headphone amp drives smaller speakers just fine. :cool:
a F5 is a much bigger amplifier, 20 watts into 8 ohms.
also, not a transconductance amp, and has feedback
If you want a transconductance amp, F1 or F1J both of which really like very low impedances and have significantly higher thd.
On 12/24/2015 at 0:10 PM, GrindingThud said:
Ooo, looks like a great winTer project. :)
small size, very low parts count, very low heat output, very large sound....
looking forward to hearing what you think of it!
Its different than the CFP2, I like both a lot..
Edited by congo5
missing T
Winer project?
drinking 1994 BV George's de latour now.
left over from last night. Yumm
14 hours ago, kevin gilmore said:
Winer project?
Now that sounds like a much better project! :)
