transconductance amp
I could probably be into trying one of those with my orthos. See if it can unseat the DynaFET...
  • Replies 112
  • Views 41.8k
  • Squeezed this amp into a small Modushop case. Tight fit for the caps, but it works. Doesn't get particularly warm. An interesting alternative for planars.
  • I forget to hang some photos of this amplifier. Sorry, I did not have any GRLV at that time ready.
  • kevin gilmore
    kevin gilmore
    http://gilmore.chem.northwestern.edu/currentamps.jpg
I have my doubts about that ... However, the interesting thing (for me) is to try it.
  • 4 weeks later...
First, thanks to Dr. Gilmore and Soren!
My amp is working and everything is OK. It's perfect with low impedance and miserable sensitivity headphones.
B: +/- 29Vdc
~2.1/50=41mA (L) 43.2mA (R)
~2.2/562=3.7mA (L) 3.9mA (R)
Voltages are a bit lower than Congo5 but I think it´s correct.
I start working on the chasis now. I´ll install a switch to select the gain as I did in the SquareWave.
P.S. I know I have to put a photo to fulfill my part of the deal. I'll place it this weekend. ?
Edited by jose
After 1 hour voltage on 562r fall to 1.9Vdc.
This was completed an hour ago.  It worked though I did not do any measurement.  I tried it with my only planar Hifiman HE6.  The volume was a dummy.  I used a preamp.  I could not afford a decent volume control for individual headamps.
Edited by samsie
Could anyone repost the schematics? Have never been able to visit gilmore's website...:mellow:
Find "currentsource" here
I´m working on a F2J. It will be very interesting. I had not had any experience with this type of amplifier until now.
I don´t think that it´s a "definitive amplifier" (I'm in love with the balanced Dynahi) but as an alternative it's not bad for the planars.
Thank you very much sir, thats one big treasure of schematics:rolleyes:
You have to thank Dr. Gilmore and everyone who has worked on it.
On 2/29/2016 at 10:39 AM, wink said:
More realistically 2.27/35 = 0.0649A = 64.9mA.
Please guys, could you explain this to me?
I understand that 2.27volt. goes through 50r. Why replace it with the impedance of the headset?
Gain selector is quite a hit. I'm enjoying it enough!!!
F2J and the KG Transconductance Amp have a very similar behavior; they shine with impedances between 30r to 75r from there they lose a lot.
  • 3 years later...
I came across this amp and I'm wondering if this can run a pair of fullrange fostex horns (96db and 8 ohms min).  Apparently they thrive being current driven and aside from Pass F1/2, pickings are really slim. As my Chord Mojo2 can run them quite appreciably loud (from a battery no less). I'm looking at headphone amps.. Any advice appreciated!
