November 13, 201610 yr comment_746132 Dusty could be right about phase cancelation. I usually try the cheapest/easiest solutions first so try moving the subs then speakers than listening position,.. well, you know the drill. And work with your ears until it seems like you've made a real difference. Don't get too in love with the measurements. Report
November 13, 201610 yr comment_746135 For me the thing that was causing a phasey sound in the bass was the chimney above the fireplace. That gave an organ pipe resonance at 30Hz and harmonics (60, 120 etc Hz). Cured it by stuffing the chimney with a load of old clothes that I'd been storing up for gardening etc in. I was keen on using Monster Traps on the rear wall http://gikacoustics.co.uk/product/gik-acoustics-monster-bass-trap-flexrange-technology/ which were very affordable. Unfortunately the WAF actually went negative, something I did not think was possible. That was very much a one sided discussion Edited November 13, 201610 yr by Craig Sawyers Report
November 13, 201610 yr comment_746140 I have a friend in the UK that makes bass traps that actually look very nice, although they often have a theme of pop and/or rock, because he'll use use concert T-shirts and the like, but I'm sure he can adapt them to something more WAF-friendly. Do you want me to ask him what the name of his business is? Report
November 14, 201610 yr Author comment_746180 Things are sounding much better - I really improved the stereo imaging in the process.I am probably going the GIK Acoustics route next - ordered a Gilford of Maine swatch book to pick out some fabric... I also have some ideas on how I will permanently integrate the ULN-2 into my system, now that I am comfortable with it. It sounds quite nice.Final graph - each line is combined stereo from the listening position (the difference between the lines was some experimentation with two different phase plug configurations on the Lowthers)Hoping to smooth things out a bit with treatments and trap the heck out of the bass. Report
November 14, 201610 yr comment_746183 1 hour ago, luvdunhill said: - ordered a Gilford of Maine swatch book to pick out some fabric... Straight guys, heh. Report
November 14, 201610 yr comment_746197 19 hours ago, Dusty Chalk said: I have a friend in the UK that makes bass traps that actually look very nice, although they often have a theme of pop and/or rock, because he'll use use concert T-shirts and the like, but I'm sure he can adapt them to something more WAF-friendly. Do you want me to ask him what the name of his business is? That good sir would be most helpful - thanks! Report
November 14, 201610 yr Author comment_746221 16 hours ago, swt61 said: Straight guys, heh. heh. okay, since you spoke up Current wall color is this: https://www.sherwin-williams.com/homeowners/color/find-and-explore-colors/paint-colors-by-family/SW6204#/6204/?s=colorDetails&p=PS0 Suggestions from here? https://www.guilfordofmaine.com/patterns/2100 I'm thinking something that is a near match or would blend. Report
November 14, 201610 yr comment_746234 Stream 2100-757 Don't listen to Dusty's future recommendation of Iris 2100-798. Edited November 14, 201610 yr by swt61 Report
November 14, 201610 yr comment_746240 36 minutes ago, swt61 said: Don't listen to Dusty's future recommendation of Iris 2100-798. Heh. Actually, I really like Amethyst, 2100-424, but would probably recommend (none more) Black 2100-408 -- would go with anything! But damn, that Iris shore is purdy! Good eye, thinking I'd like it. Do you know, I even prefer the purple mouthwash. I just have to make sure not to confuse it with the purple window cleaner when I come home from shopping. Report
November 15, 201610 yr Author comment_746255 Stream 2100-757 Don't listen to Dusty's future recommendation of Iris 2100-798.I was thinking Eucalyptus Report
November 15, 201610 yr comment_746258 Eucalyptus and Stream are the best matches. Maybe Eucalyptus even more so, as it has more of the Grey in the Green. I would either match the color as closely as possible, or go with a completely different, yet complimentary color. The best complimentary color is the opposite on the color wheel, which in this case is Red, but if you go that way you need to repeat the color in the room a few times. For example, a predominantly Red painting, a large Red vase, Red pillows on the sofa etc... Edited November 15, 201610 yr by swt61 Report
November 15, 201610 yr Author comment_746266 Maybe Eucalyptus even more so, as it has more of the Grey in the GreenMy work is done. Report
November 15, 201610 yr comment_746277 3 hours ago, swt61 said: Eucalyptus and Stream are the best matches. Maybe Eucalyptus even more so, as it has more of the Grey in the Green. I would either match the color as closely as possible, or go with a completely different, yet complimentary color. The best complimentary color is the opposite on the color wheel, which in this case is Red, but if you go that way you need to repeat the color in the room a few times. For example, a predominantly Red painting, a large Red vase, Red pillows on the sofa etc... I thought you were supposed to go 2/3 of the way around the colour wheel. Report
November 15, 201610 yr comment_746293 Maybe that's how they do it in Canada, because the colour wheel might be different than the color wheel. Report
November 15, 201610 yr comment_746310 9 hours ago, Dusty Chalk said: I thought you were supposed to go 2/3 of the way around the colour wheel. Why would you go 2/3 of the way round, when you can just go 1/3 round the other way?!?!? That's just silly . Report
November 17, 201610 yr Author comment_746541 On 11/14/2016 at 9:12 PM, swt61 said: Eucalyptus and Stream are the best matches. Maybe Eucalyptus even more so, as it has more of the Grey in the Green. I would either match the color as closely as possible, or go with a completely different, yet complimentary color. The best complimentary color is the opposite on the color wheel, which in this case is Red, but if you go that way you need to repeat the color in the room a few times. For example, a predominantly Red painting, a large Red vase, Red pillows on the sofa etc... Here they are in the flesh. Lighting makes it a bit harder I think. These should be full resolution links: https://drive.google.com/open?id=0ByiOVOm07uqqMkVsR0FISGdZQUE https://drive.google.com/open?id=0ByiOVOm07uqqd2tpR1h1TlVxMEk Report
November 18, 201610 yr comment_746564 I think I like the bottom left best. I assume that's Eucalyptus? Report
November 18, 201610 yr Author comment_746582 The lower left is my favorite too. It's Silver Papier. Eucalyptus is two up from that. Here are these two in my bathroom, which is the same wall color but with way more lighting. https://drive.google.com/open?id=0ByiOVOm07uqqWGh3bENsRWZyNFU Report
November 18, 201610 yr Author comment_746593 @swt61 also the Silver Papier isn't a solid color like the rest and has more texture and some whiter streaks in it. It's more obvious in the last picture. Report
November 18, 201610 yr comment_746608 Just goes to show that you can't tell shit from a computer screen. I like the Silver Papier, and I like the variegated or heathered effect. Report
November 18, 201610 yr Author comment_746657 Well, ordered. Also, Silver Papier is an "in stock" color and cheaper. I can't wait to get them and hopefully it won't be too tricky to get them installed. I have some electrical work to do in the room and reconfiguring the closet. Then I want to do some recessed lighting (doesn't look too hard to DIY, mostly need to map out where the joists are above) then will look at the ceiling treatments. That's my end year goal for the room. Report
