vertek Posted June 11, 2018 Report Posted June 11, 2018 What is the replacement of the stable pressure pipe? Z4 Anybody know, thank you! STAX SRM-007TA Z3, Z4 Bose sealed diode,
JimL Posted June 11, 2018 Report Posted June 11, 2018 As best I can tell, I believe you are referring to zener diodes Z3 and Z4, which are 47volt rated in the SMR600, and presumably the same in the SRM007. It would be less confusing if you didn't make up your own names for components.
vertek Posted June 12, 2018 Author Report Posted June 12, 2018 Thank you, Voltron, JimL, the two heroes. The serial number in Stax SRM-600 is Z5, and Z6 will also hang up the element.
lkong Posted June 12, 2018 Report Posted June 12, 2018 (edited) My guess is pressure = 压力 = 电压 = voltage? stable pressure = 稳压 = voltage regulation? So the whole thing translate to: I'm gonna be rude here, but you will have to give me the answer. Edited June 12, 2018 by lkong
Kung Posted June 13, 2018 Report Posted June 13, 2018 the jr audio on taobao? i know you,you're a fan of spritzer.
lkong Posted June 14, 2018 Report Posted June 14, 2018 (edited) Fremdschämen Edited June 14, 2018 by lkong
