DIY mini T2 Build Thread
3 hours ago, Shawn said:
BTW there is a wire cut in your back here but I believe it's the software problem.
Yes, a small problem with the 3D viewer... only a 1200 USD software.
The LT1083 thing looks nice - is that your own design?
  • Replies 336
  • Views 129k
  • Half a year ago I promised to build a new original DIY T2. Now it’s done. After some difficulties with left channel and PSU she is playing as an original DIY T2 does!!! Thinking of retire a
  • dingding123
    dingding123
    Finally, my mini T2 is completed. Just want to share my build experience and listening impression for those who are about to build one. Also, a huge shout-out for JoaMat, who conceptualised and design
  • A few points regarding the boards Michael have had made on my gerbers. They are basically the same as my kitchen made boards I made  five months ago. The small tube footprint has no hole for the
mini T2 DHT – for Emission Labs 20B-V4 tubes. Here with 2A3 and adapter from octal to 4-pin. BZ8A0591.JPG
The tube filament is injected to the adapter from 9VAC via rectifier and step-down DC-DC converter. Trimmers for voltage and current limit. I use it for 2.5V to 6.3V heaters.
Edited by JoaMat
Not original from me. I found it on Alibaba and made some changes to it.
Here is the schematic I drew it under 10 mins. Well... not perfect but readable.
The size is 96mm*35mm. Still can shrink it down by removing the heatsink and attaching it to the chassis. What is the size of your DC-DC converter?   And your pics remind me I have a bunch of 20B-V4 sitting in my garage for yrs. How do you convert the circuit to adapt 20B-V4?😳
AC Out should be DC Out.
Edited by Shawn
 Tanks for the schematic.
The DC-DC converter itself is 62mm x 26mm. Board with rectifiers, electrolytics and converter module is 91mm x 33mm per section.
No changes to the circuit more than the tube change and its filament arrangement.
The size is impressively small. What is the heat generation of it?
Excuse me for one more question, JoaMat. Here are the socket views of 6CA7 and 20B-V4.
To convert the 6CA7 to 20B-V4:
1. Pins 1 & 2, Pins 6 & 7 will be supplied by 5VDC instead of 6.3VAC.
2. Each 20B-V4 needs to be powered by separate supplies.
3. The Pin 8 which is CT on 20B-V4 remains the same since it's the Cathode on DHT.
4. Disconnect Pin 4
Please correct me if I'm wrong. Don`t really want to massive and fry those expensive tubes.
Don`t know what to do with Pin1(G3). And there is a 220Ohms resistor between Pin 3&4 and 22KOhms between Pin 2&5, Do I need to change it?
image.png.15318327b88e4a3630f7f9244ace6757.pngimage.png.c54249d31e59d39435d9082044404b3f.png
Below is my way to describe how to prepare mini T2 for EML 20B-V4.
  1. Cut traces to Pin1 (G3).
  2. Cut traces at heater pins connected to resistor string 120K, 300K, 300K, 300K (one per channel). Purpose of the sting is to create -400V potential for Pin5 (G1) via 22K resistor.
  3. Remove 220R resistors.
  4. Remove 22K resistor
  5. Find a solution to put 22K resistors from Pin5 (G1) to resistor string between 120K and 300K resistors. This is probably the trickiest part.
  6. No heater wires between tubes of course.
I’m sure you can modify your mini T2 to take the 20B-V4 tubes. But, maybe one should make a new board for the Emission Labs tubes…
Not much heat produced by DC-DC converter supplies. No heat sinks needed.
On 3/17/2025 at 11:25 PM, JoaMat said:
I’m working on a new version of a mini T2 board. STN9360 replacing KSA1156 and also moving offset  servo up on tube side of the PCB – making it easier to replace a faulty OPA197. No problem with balance servo… knock on wood.
Done some more work. Added a couple of zero ohm resistors round the output tubes and a few other changes. If 20B-V4 tube remove the zero ohms and 220R resistors.
Pcb layout is more fun than Sudoku.
Edited by JoaMat
Here is the draft based on your description.
Regarding No.5, Should I pull the right-hand side(picture below) Pin5(G1) also to the resistor string between 120K and 300K resistors? Also Could you double check if there is anything I missed? Ignored the blue traces that go to KSC2690A and O-.
I will be working on the new layout after making sure it is correct.
You know what? You are at another level of speed. I was thinking about your description and gonna say the zero jumper is the solution and you did it!
Edited by Shawn
1 hour ago, Shawn said:
Should I pull the right-hand side Pin5(G1) also to the resistor string between 120K and 300K resistors?
Yes.
Upper left tube: from pin1 (G3) is a blue trace connecting Pin3 (A) - must be cut, but you probably have done that.
Really an exciting project.
Edited by JoaMat
Done. Credit to JoaMat.
Instruction again for 20B-V4 each channel:
1. Remove JP1~JP3(JP1 on the back which is connect Pin 1 & 3).
2. Remove two 220 ohms resistors.
3. Remove the right-hand side 22k ohms resistor.
4. Wiring the two pads which are marked as 20BV4.
5. Separate heater power supply.
Based on layout ver.23.
Hope this instruction can help someone keep investing in their mini T2.😊
Edited by Shawn
22k fixed. Picture updated
I believe you should move 22K resistor right tube to between G1 and 20BV4 pad.
Then wire the 20BV4 pads together for bort EL34 and 20B-V4.
Edited by JoaMat
Edited and fixed.🤞
I will work on the CNC enclosures next week. The drilling hole patterns will match any layout versions from .2~0.23.
Just send the Gerber to the factory, Can`t wait to listen to it.
Edited by Shawn
Okay. After multiple checks for the occasional humming issues for a week.
I finally learned the lessons. Separate each channel into individual space connectors. The two EL34 heater cables can`t go through the same connector(or be too close). The two 460V rails may have interference with each other, but I don`t have the knowledge to explain it.
mini T2 board prepared for octal or UX4 sockets. Octal socket overlapped with UX4 (red arrows).
If EML 20B-V4 or 300b/2A3 remove components at red arrows. If 300B/2A3 tie pads in green boxes together.
Edited by JoaMat
mini T2 ver.25 is starting to take its final shape, I think. I'm filing a little now and then. A small test board made now after coffee...
here with UX4 socket. The connectors are from Electrokit https://www.electrokit.com/pcb-hane-5.08mm-2-pol-lagprofil and https://www.electrokit.com/skruvplint-pluggbar-5.08mm-2-pol-lagprofil. It is possible to use a regular 2-pole screw terminal, but I think the connectors in the pictures are much more practical. The circuit board connector in the pictures is notched in each lower corner with a sharply sharpened Japanese master chef's knife to fit between the solder islands.
P.S.
AI translated - I'm lazy:popcorn:
Hi JoeMat,
I'm very interested, how can I purchase a pair of board? and which ps board should I use? Thank you.
I have no boards left. Last pair sent to Finland some months ago.
I’m working on an updated version of mini T2 boards. A senior Head Caser is test building - he has not approved the boards yet.
I use a Gilmore DIY T2 PSU for all my electrostatic amplifiers including mini T2. But you probably want to use something more suitable. There are several PSU boards to choose from here https://drive.google.com/drive/folders/1r3g2TAtBUaBdiMorTWX7yYgeJ7maQbYW?usp=sharing .
Glad to hear you are still updating the design, once you finish the design, will you open a new batch of GB? Thanks.
Personally, the best way right now is to get the KG T2 instead. No SMDing required, but not budget friendly. The mini T2 still needs to be tested for a while.
I can report that JoaMat's new mini T2 boards are working as designed/intended.
This is with EH 300b and Amperex 6DJ8 and same filament regulators as JoaMat has shown before.
Have only listened to it in mono (which sounded great) since I managed to blow channel nr 2 by re-using a 1N100D that I thought was fine but which wasn't. Lots more current through one of the lt1021's than designed for and it blew after a couple of minutes.
Spare parts are on order so expecting to get back to a stereo setup by the end of the week.
If you intend to build this, get yourself some 1N100D now. The only place I found with some in stock before next year is TME and it's dwindling fast (was 115 this morning, is 83 this moment).
Edited by MLA
If problem to find 01n100d go for 10m90s. Works great in Sweden.
Also, STN9360 (replacing KSA1156) seems to work.
Edited by JoaMat
Do we need to change the 787 Ohms(R24, R25) Resistors if 10M90S instead of 01N100D?
Still have a couple of 01N100D and 10M90S on hand.
Edited by Shawn
No change needed.
With LT1021-10volt the current is 10V/787ohm + 1 mA from ground pin = 13.7mA.
One builder increased current to 18mA by changing resistor to 590R. Now I use 590 as well in my mini T2 DHT with Emission Labs tubes and I’m happy.
mini T2 with new boards. STN9360 replacing the obsolete KSA1156. Here the 01N100D are replaced with 10M90S and it works all right. The amplifier is configured for EL34/6CA7.
Amplifier for 300B by member mla a few posts up. He also have 6A3 - see if he can be persuaded to test them.
IXTP10M90S can be replaced with IXCP10M90S(TO-252). If KSC2690 can be replaced by something else with an SMD package, we can eliminate all the aluminum oxide isolations.
BTW, what is your grounding strategy?  Seems like the ground pins of the XLR input go back to the PSU enclosure.
